Not so much done today, the lack of light caught up with me.
I experimented with diodes for the lighting circuit and decided a bridge rectifier was better than two diodes, mainly because it had a hole in the middle which would allow me to screw to something or other. Also need to consider the current. Each of the LED strips is about 0.7A and I have six of them, so about 4.2A. A 6A bridge rectifier was chosen. More on the lighting and a final circuit diagram later.
The LED strip light was finished off with a terminal block in the right place to match the hole in the roof centre panel. The centre panel was cut and covered, but waiting for paint to dry on a bracket I made for the rear end.
Carpet cut and sprayed with glue.
Panel also cut and sprayed with glue. Not two holes - the small one is for the terminal block on the back of the LED strip light and the bigger one is where the original light would be. I've put a hole there in case I need to get to those wires in the future, but will cover it and leave it covered.
Carpet wrapped onto panel and smaller of the holes cleared.
The bracket that will hold the back end up, made from angle ali with the corners sanded down.
