djvirus mk5 camper conversion/restoration
Re: djvirus mk5 camper conversion/restoration
Postby djvirus82 » Fri Jul 22, 2011 9:07 am
djvirus82
Postby djvirus82 » Fri Jul 22, 2011 9:09 am
as you can see i will be getting my flashdance moves going to sort out the old tin worm!!! :lol:
djvirus82
Postby djvirus82 » Fri Jul 22, 2011 9:10 am
djvirus82
a rare delight!!! a mint side step!! :D
djvirus82
Postby djvirus82 » Fri Jul 22, 2011 9:11 am
djvirus82
Postby djvirus82 » Fri Jul 22, 2011 9:12 am
djvirus82
Postby djvirus82 » Fri Jul 22, 2011 9:14 am
this will just fit, just! I was thinking across the back doors width ways and then sink and cooker units across back of seats!! what do you guys recon the best layout is for a swb shr?
djvirus82
Postby madbri » Fri Jul 22, 2011 9:16 am
what u doing about the floor? cutting it all out and patchwork? or fit a complete floor?
madbri
Postby djvirus82 » Fri Jul 22, 2011 9:20 am
not sure yet when i attack it with the grinder and see just how bad it is, i will make an educated.
djvirus82
Postby madbri » Fri Jul 22, 2011 9:47 am
im sat here thinking id probly rip all the floor of then do all ure work that needs doing on ure outriggers stood up thats if u need any work on them :wink:
madbri
Postby djvirus82 » Fri Jul 22, 2011 10:32 am
that could be a plan, bri. chop it all out, guna get the back end up and drop axel off and exhaust and tank, clean axel up change diff oil and replace brake pipes and brake shoes/cylinders etc if they are needed. exhaust has seen better days and im going to have a side exit anyway all down the sill - hot rod style!!!
djvirus82
Postby AlanN » Fri Jul 22, 2011 3:31 pm
If you chop it all out get a floor pan, got to be easier in the end.
Postby djvirus82 » Fri Jul 22, 2011 6:34 pm
think i will probably go for the full floor, just bin on fleebay and they are 135 quid, going to try beevers in the morning, it only 2 mins from my house, if not al just get a big piece of sheet metal and make my own, remember to wear a mask this time tho, got arc eye welding a recovery truck once c*** see for 3 days!! :lol: 8)
djvirus82
Postby djvirus82 » Sat Jul 23, 2011 5:41 pm
NICE 1....just won a slidding window and a gas heater on fleebay, for the quite frankly, might as well av stole em £27.50 for the pair. :D
djvirus82
Postby djvirus82 » Mon Jul 25, 2011 11:26 am
not much happen over the weekend but did manage to get 1 side of the old insulation and fibreglass off and reinsulate and get ready to cut drivers side panel out for my slidding window instalation. floor will be getting cut out this week and should be done and welded up by the weekend, so i can crack on with getting the new floor down and carpet and side panels etc.
djvirus82
