mk2 petrol to turbo di hopefully
Re: mk2 petrol to turbo di hopefully
Postby Luke » Thu Nov 17, 2011 8:04 pm
tonypastie1 wrote:Will be selling the 5 speed pinto I paid £100 ands that's what I want back it's perfect box and a transit box not a sierra box
it's the same box as the Di - do you know the one on the tourneo is any good :?:
Postby tonypastie1 » Thu Nov 17, 2011 8:26 pm
So u saying the di turbo engine will fit to my 5 speed pinto?
IF yes I got 2 spare di boxes one with the tourneo and one I had from another scrapper
tonypastie1
Postby tonypastie1 » Thu Nov 17, 2011 8:43 pm
Ford etis says tourneo has mt75
tonypastie1
Postby MinorMatt » Thu Nov 17, 2011 9:00 pm
The diesel should bolt up to the pinto type 9 box - but you will need a diesel pinto clutch...
Personally I would keep the tourneo gearbox on the engine and use the propshaft off the tourneo too (but you may need to get it modified & balanced)
Postby Luke » Thu Nov 17, 2011 9:00 pm
oh sorry is your 5 speed a type 9 :?: i thought it was an MT75 :|
if so then yeah sell it ........... if it's an MT75 with adapter plate to fit a pinto - it'll be the same box thats in the tourneo :D
Postby Luke » Thu Nov 17, 2011 9:06 pm
yeah i agree with matt keep the MT75 :D if you cut this bit of floor out of the tourneo it'll fit like a glove on your mk2 floor :D then you'll have loads of clearnace and be able to change the clutch without removing the engine :D
Postby tonypastie1 » Thu Nov 17, 2011 9:17 pm
best cut my disc cutter out:)
do any of you guys no if the turbo engine wiring loom is seperate from the rest of the loom in the tourneo?
as i am think possibly using the whole loom and the epic pump as it runs well at the moment but i do have a bosch manual 146 pumping as well just in case
anything i need to consider before i jump right in !
tonypastie1
Postby MinorMatt » Thu Nov 17, 2011 10:11 pm
The epic loom is integral to the dash loom - however I expect with quite a lot of time and patience it wouldn't be too difficult to split it out?
Bosch pump is definately the easiest way to go though!
Postby tonypastie1 » Thu Nov 17, 2011 10:14 pm
bosch pump looks a winner but what about the sensors on the pipes and all the vacum things hanging about? or just leave them un plugged?
seems a shame to dismantle something that works fine :) (still want the bosch matt)
tonypastie1
Postby MinorMatt » Thu Nov 17, 2011 10:19 pm
none of the sensors are needed so leave them unplugged.
When the engine comes out there will only be 1 boost pipe which needs to be unplugged and this just needs to be blanked...
Feel free to ask any questions when I come and visit... its often easier to show than explain...
Postby tonypastie1 » Thu Nov 17, 2011 10:26 pm
will do
dont worry shall be asking :)
tonypastie1
Postby MinorMatt » Thu Nov 17, 2011 10:26 pm
I can't hang around for more than a few hours... :lol:
Postby Vandalism » Fri Nov 18, 2011 11:31 am
did you say you where going to keep it lhd of change it to rhd :?:
Postby tonypastie1 » Fri Nov 18, 2011 9:40 pm
keep it lhd :) suits the rotherman style i am planning as ford rally vans were lhd for european sport
tonypastie1
Postby mr Grimly » Fri Nov 18, 2011 10:43 pm
lhd the way to go ! 8) 8)
mr Grimly
