My MK5 Minibus Project
Re: My MK5 Minibus Project
Postby Muttley » Mon Jan 07, 2013 8:31 pm
RonTransitmk5 wrote:
Muttley wrote:I have central locking on my spec truck that caught fire, the control unit is ruined but the solenoids and fittings are still on the doors if you want 'em :)
Hi Muttley,
I'm interested in whatever parts I need to get c/l working on me front 2 doors m8
How much you looking for? What other bits would I need to complete? control unit/key fobs
thanks Ron
You would need a control unit and fob, you can get these from ebay, I dont want owt for the bits but they are down in Pirbright still on the truck, maybe I can get 'em off soonish but if you are in a hurry then just use the bits in the ebay kit :wink:
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby RonTransitmk5 » Mon Jan 07, 2013 9:24 pm
robbie.cee wrote:Nice where did ya get the unwin stripping from?
Looks like ill be bolting straight thru floor as still,not got legs or strip or clamps...
I do however have a nice steel bed frame to chop up n weld!
I managed to get the lot via the bay, just seen a thread with pics on another forum showing hows its done
Like you say just bolt straight thru floor, 12mm ply inbetween & can cover in industrial vinyl for clean finish.
Trouble is will need countersunk flat head bolts for a neat finish & for the seats to slide £49.76 + postage for pack 100 or £6/10+ direct from Unwin, just got their price list, their parts are so expensive. Will shop about elsewhere in the morning.
2003 Ford Transit Connect 1.8 TDDI Red.
1999 V reg MK5 Bus(M2) Mid Roof, 2.5di, diamond white. GONE
RonTransitmk5
Postby RonTransitmk5 » Mon Jan 07, 2013 9:37 pm
cheers Muttley I will proberly go with the cheap ebay kit or remote alarm option.
Thanks for the offer of bits
RonTransitmk5
Postby RonTransitmk5 » Tue Jan 08, 2013 6:20 pm
Could not get the fittings locally or on the bay so have placed an order with Unwins, the fittings cost more that the seats/clamps/track :x
Ordered some Vactan to cover all the fittings during installation to hopefully help keep the rust at bay, need to stock up on some good quality drill bits as approx 120 holes to do :lol:
Going to get new 12mm plywood/chipboard/mdf & some industrial vinyl so I can replace the compete floor covering & get a good flush finish against the rails.
What do you guys think I should use for the floor, the chipboard & mdf is about the same price, the plywood is double the price of chipboard/mdf?
Decided I will do the sides & bulkhead after but will carpet them instead of vinyl, just so it all looks good together.
Whats the best way to fit the bulkhead & sides in, screws/glue?
Should I wax/oil/Vactan treat & insulate the sides at the same time?
Going to do something with the ripped/dirty headlining as well, should I do this before or after the sides & bulkhead? or does it not matter
RonTransitmk5
Postby robbie.cee » Tue Jan 08, 2013 10:57 pm
ply boards dude as water proof- or more than mdf n chip board!!! :wink:
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby jolly olly » Tue Jan 08, 2013 11:26 pm
robbie.cee wrote:ply boards dude as water proof- or more than mdf n chip board!!! :wink:
X2 it's worth spending the extra so you only have to do the job once, just varnish / seal the exposed ends.
Life is not a dress rehearsal
jolly olly
Postby robbie.cee » Wed Jan 09, 2013 9:28 am
U would be best red oxide floor then lay already painted n cut boards
And strips n bolt all down.
Sides
Then roof last but need many hands for roof lining!
Had
MAKE IT FIT
robbie.cee
Postby RonTransitmk5 » Wed Jan 09, 2013 6:09 pm
Thanks for the advice
RonTransitmk5
Postby RonTransitmk5 » Sat Jan 12, 2013 1:23 am
Rear interior stripped
RonTransitmk5
Postby RonTransitmk5 » Sat Jan 12, 2013 1:27 am
1.5l Red Oxide arrived robbie.cee
RonTransitmk5
Postby transit mark » Sat Jan 12, 2013 8:40 am
Any idea what i need to fix the seats to the tracking?
Mark
2001 MK6 90PS MWB RWD
transit mark
Postby robbie.cee » Sat Jan 12, 2013 11:49 am
Special feet that lock into tracking!
Ron mate the red oxide skins and sets quite fast so keep stirring and do small areas at a time!
Had
MAKE IT FIT
robbie.cee
Postby transit mark » Sat Jan 12, 2013 6:18 pm
Are they expensive.
Mark
transit mark
Postby RonTransitmk5 » Sun Jan 13, 2013 10:07 pm
transit mark wrote:Are they expensive.
Mark
I think they are, info below is taken direct from Unwin price list e-mailed to me 2 weeks ago so up to date.
Standard Removable Seat Fixture -M1 £36.52 Each (You will need 2 per seat = £73.04)
They sell other types which cost even more;
HAL with 2 fixing bolts-HAL2 £46.57 Each (£93.14)
HAL with 3 fixing bolts-HAL3 £46.57 Each (£93.14)
RonTransitmk5
Postby RonTransitmk5 » Sun Jan 13, 2013 10:20 pm
Here's a picture of my seats & the fittings
RonTransitmk5
