My mk6 swb
Re: My mk6 swb
Postby Punto443 » Sat Jul 06, 2013 7:13 pm
Got my shinny be heated screen fitted and some new pillar clips too! :D
Means I don't have to drive below 50mph now :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby Altransit » Sun Jul 07, 2013 12:18 am
How much wiring did you need to do for the Heated Screen :?: Was anything there already :?:
Re: My mk6 swb
Postby Punto443 » Sun Jul 07, 2013 1:44 pm
Ill do a wee run through what I done when I get home, but it was pretty easy and I had no existing wiring at all :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby Altransit » Sun Jul 07, 2013 1:46 pm
I would love to have one in the MK6, and the screen does have a crack in it :wink:
Re: My mk6 swb
Postby Punto443 » Sun Jul 07, 2013 3:13 pm
Ok, i had given up on the idea of fitting because it looked like a lot of hassle! but on one of my scavenging hunts i got a complete dash loom and relays for £15. I tried swapping this but it was damaged! C/l faults and instrumentation :x
So I unpicked the heated screen wiring.
All I had in the existing van was the two 40a fuses in the engine bay, not even the pillar wiring was there.
The two 40a were live and ran back to the main plug between engine and dash, so I took the connector apart and slotted in the two feeds to the dash fuse board( there was two empty relay ports on this)
And I transferred the wires one by one, the switch wire was run back the the dash and the illumination and earth wires spliced into the the mirror switch as it had been on the original loom.
The heavy cables were run to each corner and the earths connected to the existing points at each wheel arch, then the pillar wiring dropped down to connect to the wheel arches
I robbed the switch power from the rear wiper motor relay( unused and the correct amp) this is the only wore that was not factory like :D and the switch earths at the relay were spliced into the other relay earths under the fuse box as per original.
Lastly the other side of the 5amp fuse was clicked into the dash fuse box and a fuse popped in, as per the original.
All taped back to the original loom and looking as good as new :D
Then £175+vat for the screen fully fitted by euro windscreens( I was quite surprise at how cheap it was, considering it was £115 for a standard one) and my excess was going to be £100 if I'd claimed!
All in all up and running for around £230! And I needed a screen any way so I could say only about £100 for the heated :mrgreen:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby Altransit » Sun Jul 07, 2013 3:17 pm
Thank you Morgan 8) :D
Re: My mk6 swb
Postby Punto443 » Tue Jul 09, 2013 10:57 pm
Now that the bodywork is tided up and my screens fitted what shall I do now :?:
Thoughts running through my head inc.
Aircon
Black wheels
Remap
External speakers for when I'm working out side :lol:
Painted grill
Sport kit( bit pricey! And I hate body work :lol: )
Tailgate conversion
Crewcab
Heated seats (maybe not in this heat wave)
Or I could just drive it for a while :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby limitedblack » Wed Jul 10, 2013 7:59 pm
Alloy slot mags, proper Starskey & Hutch then :)
Happy Easter
limitedblack
Re: My mk6 swb
Postby Punto443 » Fri Jul 19, 2013 7:49 pm
GUTTED! :( my favourite donor vans away to the crusher :lol:
Farewell K... AKE you'll be missed :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby blue estate » Fri Jul 19, 2013 7:52 pm
Punto443 wrote:GUTTED! :( my favourite donor vans away to the crusher :lol:
Is there any thing left to take to the crusher ? :lol: :lol:
blue estate
Re: My mk6 swb
Postby Punto443 » Fri Jul 19, 2013 7:55 pm
Just the chassis :D And ake left a old radiator in the back and a daily record in it :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby Punto443 » Fri Jul 19, 2013 10:05 pm
Grill fitted, just needs a good clean and polish :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby ake » Sat Jul 20, 2013 8:58 am
I'm still amazed it was around this long!
Still lots of it lives on in your van :)
Re: My mk6 swb
Postby Punto443 » Sun Jul 28, 2013 10:00 am
Decided to crewcab the back, with 2 seats and a staggered bulkhead. So went the breakers for some parts and ideas :D
Picked up seats with built in belts
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby Punto443 » Mon Jul 29, 2013 4:33 pm
Got a bit done over the last few days
Bulkhead formed
Head cloth fitted
And a bit of trimming :D
That glue is some fragrant stuff, head was spinning for ages :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
