Red one
Re: Loots mk7 keeper
Postby loot » Sat Mar 29, 2025 11:00 pm
Loots chop shop is in full swing. Tonight was spent mostly spot weld drilling. You all yourself,but mr loot...... Why?
And the most Apt reply I can muster is fook knows :lol:
Ids map here
loot
Postby loot » Tue Apr 01, 2025 10:16 pm
Made a convertible :P
Ids map here
loot
Postby ned » Wed Apr 02, 2025 4:18 pm
Nice how low is the roof chop gonna be 6” are you putting a low roof on or high top/pop top, you know with the donor van you could make a funny van where you cut the middle out.
Quick question are the outer cills spot welded to the inner cill
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Wed Apr 02, 2025 11:10 pm
ned wrote:Nice how low is the roof chop gonna be 6” are you putting a low roof on or high top/pop top, you know with the donor van you could make a funny van where you cut the middle out.
I'm stitching the low roof on from the tourneo it'll be factory. :P
I might cut the middle out and fit a pop top. But that's a later project. I've still got loads to do, insulation, tourneo interior,stretch carpet etc, there's a leak from the gearbox to engine seal. I'm interested in fitting a mustang automatic gearbox if possible. Remap possibly. I did have the pcm in it from snowflake but I had to install the original map. I could put a 3.2 pot in it if I wanted. Also I'm interested in upgrading the speedo and adding sync 3. If possible.
It's a long term project and I can get it on the road first.
Panels are all spot welded, they sandwich together. Did you post a picture of your panels anywhere? There's genuine fit ones or repair panels which are different. They're doesn't appear to be factory inner sills available for the non sliding door side :x
Ids map here
loot
Postby ned » Thu Apr 03, 2025 6:48 am
Hmmm skies the limit really isn’t it, how about a bmw twin power turbo diesel, my eldest has a 1 series with the 2.0L engine 180 bhp from factory, mate that with an auto box, lsd and line lock it’ll be burn outs for days, bet your glad you bought the lair all those years ago.
Tbh I don’t know what I bloody bought or when I’ll get time to do the repair, I’ll make these fit :lol:
ned
Postby loot » Thu Apr 03, 2025 2:11 pm
ned wrote:Hmmm skies the limit really isn’t it, how about a bmw twin power turbo diesel, my eldest has a 1 series with the 2.0L engine 180 bhp from factory, mate that with an auto box, lsd and line lock it’ll be burn outs for days, bet your glad you bought the lair all those years ago.
You should be able to look back at this thread for when I did the front on mine. Have you got any pictures of your holes that need repairing?
Ids map here
loot
Postby ned » Fri Apr 04, 2025 1:04 pm
See the brown bits well under the door rubber isn’t brown it’s fresh air,
The inner cill where the mud flaps attach was plated t’other year for the mot so I’m thinking cut the cill off below the step and see how bad the inner cill is and either change both and the arch or just the step cill for now, the arch behind the plastic is non existent either, bloody ford
ned
Postby loot » Sat Apr 05, 2025 4:59 pm
I suggest for now , remove the plastic step trim(2x10mm nuts underneath)and remove the weather strip.
See what the inner cill and step box and outer sill are like.
The bits you have bought there's 2 good bits but the middle sill panel is just a repair panel that basically sits on top and welds over it but it misses the ends, i did it on asbo as a bodge but it isn't suitable if you plan a proper repair.
If you strip it down and find the steep void it's good and just the outer sill is a bit crap you might think cut the bad out and the previous plate and so a new plate over. Otherwise it's the full job really. But you need to grind back to good metal to get a full decision. My tip is where the mudflap bolts to is the inner sill and if you can basically pull it off and make a hole then that needs doing.
Ids map here
loot
Postby ned » Sun Apr 06, 2025 8:15 am
It all came as a package so thought why not :lol: :lol: my plan is to replace the bit below the door then eventually to the arch, the inner where the flaps go left the building last year so I just bodged a plate over it
How that low roof coming along, you could fit a nice sunroof over the cab
ned
Postby loot » Sun Apr 06, 2025 4:30 pm
ned wrote:It all came as a package so thought why not :lol: :lol: my plan is to replace the bit below the door then eventually to the arch, the inner where the flaps go left the building last year so I just bodged a plate over it
Day off today as I did a triathlon, Friday I did a tansit front balljoint and an Astra j rear door that wouldn't unlock.
The donor roof panel is all prepped up so I just need a few hours to drill the bits on the van to get that ready for the donor. The van has AC so I'm not sure about fitting the sunroof, I'm in 2 minds about doing a pop top. I plan on roof rails and a nice rear spoiler. Factory look though,I'm not into bonnet bras and roof visors etc.
Ids map here
loot
Postby loot » Thu Apr 10, 2025 7:41 pm
Any smokers about? Spark a cig up for me to mark the end of the 'topping off ceremony' :P
Ids map here
loot
Postby MinorMatt » Wed Apr 16, 2025 1:16 pm
Just placed or welded too?
Postby loot » Wed Apr 16, 2025 5:54 pm
MinorMatt wrote:Just placed or welded too?
It is now placed and welded and ground and rust treated so next is to seam seal it all then the metalwork is complete. I then need to spray the van race red and then reassemble it all.
Ids map here
loot
Postby loot » Wed Apr 16, 2025 5:59 pm
Zinc spray.
Don't really enjoy welding spot welds, I would like a spot welder. I have that 1 there from Al but it doesn't have a timer :cry:
Ids map here
loot
Postby Altransit » Wed Apr 16, 2025 10:30 pm
loot wrote:Zinc spray.
Sadly the timer was nicked in one of my many break-ins at my old place :(
