spudmab wrote:well its been a crap day and its only just started,
i ordered a new side door and it turned up to day and its for the right hand side even though i was sold it as a left hand door,![]()
then i thought sod it i will get on with sorting out the kitchen area in the van so put the new drain plug inand the tap then i tryed to pump the water and the pmp seems to not work,![]()
again told it was a working pump,
then i thought sod it i will get the new gas pipe on and that works,
i filled the sink up with water to see if it was water tight and all seems to be ok,
just need to clean up the tap to make it all shiny![]()
