Oh dear..
Already two down. Thanks for the info though
Also, thanks for the comments guys
Anyway, had fun and have been busy recently with regards to t'van.
Bad(well, not really) news first though - I had another flat battery issue today
I only went and left the lights on when I got out of the van didn't I?
Not a problem though - I'm now
always carrying the spare, where ever I go, so I just switched them over.
It is a slight inconvenience when I go for a shower though
The amp and sub that I got in advance for my birthday arrived two days ago, so I spent Tuesday night fitting that. Took a few hours, but I did it all by myself, and perfectly installed too
Ended up with LOADS of spare, free high quality cable though as both the amp and sub are near the front, an I already had the speaker cables in place.
This is the sub:
This is the front of the amp that is now located underneath the passenger bench seat:
Here is the back of the amp, with all the power connections - I was lucky in that there was a ready drilled bolt hole that I could use to ground the amp to.
It is all hooked up and now happily drowns out the annoying whine of the engine on the hour long morning commute
The bass is fantastic too - I love listening to bassy music (drum and bass and UK hip hop mainly) so I'm loving having everything shaking as it should!
Last night, I winged past B&Q to pick up another 4 pack of square battens that I could use to create the box that I could keep all the van repair bits, as well as hide the sub from prying eyes.
Here's some of the bits before I started chopping it all up:
I didn't take any pictures as I was making the box. They wouldn't be very interesting and I'm sure you know what there would be anyway
So instead, here's the box finished and situated in the van:
I put the lid on with an overhang to lift it by, and added two cheap hinges. Here is proof that it all works as it should:
The extra struts are in the lid so that it can support people sitting on it. All the screws about 2.5 inches long so they'll be more than strong enough
And here is the box with the sub in it!
HUZZAH!
I'll be carpeting the box lid and sides, as well as adding a strip of carpet round the back of the bench seat as the amp can be seen underneath it.
The only problem that I have discovered so far.....is that if I take a roundabout sightly too fast, the sub and the box tip over into the middle of the van
I'll be adding l-brackets ASAP, as well as properly screwing the amp to the floor to make it a bit harder to nick, unless they happen to have a very small screwdriver
