mk4 LWB Project! UP DATE! one side nerly done in blue !!!
Re: !!Intransit89 LWB MK4 Project!!bit of polishing was board!:)
Postby Luke » Sun Jun 01, 2008 12:42 pm
are you sure your gas is actually run out :?: that size bottle should have lasted years (seriously) was it full when you got it :?: do you turn it off when you have done welding :?:
Postby MrMPuk » Sun Jun 01, 2008 12:53 pm
There was still pressure in the bottle when he posted the picture saying it was empty. Probably just needed to turn the regulator up.
Postby intransit89 » Sun Jun 01, 2008 1:24 pm
Luke wrote:are you sure your gas is actually run out :?: that size bottle should have lasted years (seriously) was it full when you got it :?: do you turn it off when you have done welding :?:
yes use to get it out the shed turn it on till you couldnt turn it then do the welding then turb it of as it says on the arrows on top till it wouldnt turn any more then back in the shed
when i tock the pipe of from the welder so i could test it as when i turned the gas bottle on nothing come out at all!
and when i got it it come out good even blow bikes over with how much the gas come out :!:
but nothing now maybe have a refill again and maybe only turn the bottle on till gas comes out in sted of full lock! :?
intransit89
Postby MrMPuk » Sun Jun 01, 2008 1:28 pm
Have you tried adjusting the regulator?
Postby intransit89 » Sun Jun 01, 2008 1:52 pm
MrMPuk wrote:Have you tried adjusting the regulator?
yes it even unscrews out! and still nothing comes out! :?
intransit89
Postby Guy88 » Sun Jun 01, 2008 2:21 pm
you screw the regulator out for LESS gas mate :wink:
also you should only need the tap on about a turn at most
you should have about 0.2 bar pressure going to the torch, you dont need full bottle pressure at the welder
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby intransit89 » Sun Jun 01, 2008 2:28 pm
Guy88 wrote:you screw the regulator out for LESS gas mate :wink:
all i can think of is before i do buy a other refill is to take the regulator as if i just got the bottle and try it again and if nothing comes out then it must be empty :? seem best to do that then :wink:
plus i can get it cheaper! ie its 60.00 to the door or if i pay dave 10.00 for diesel and got to spilsby i can get it for 14.00 for the refill and 10.00 handle charge
so about 35.00 ish just have to take some sort of sponge for the gass bottle and maybe some wheels to shop it flying around in the back of the van :lol:
intransit89
Postby MrMPuk » Sun Jun 01, 2008 2:30 pm
Your bottle still had gas in it for sure, there was still pressure on the gauge!
Postby MrMPuk » Sun Jun 01, 2008 2:35 pm
This is showing there is gas in the bottle. Turn the regulator in until you get pressure on the right hand gauge.
Postby Paul 1 » Sun Jun 01, 2008 2:57 pm
Check that the jubile clip is tight and no holes in the hoes aswell.
54 plate 260 MK6 SWB Exec pack 85 ps soon to be reemapped. Dead locks and arma plates on rear.
Paul 1
Postby lostpaul67 » Sun Jun 01, 2008 4:02 pm
How much gas does it take to 'Blow bikes over' :?: :?:
T260/130ps Glx
My Mk7 Ford Transit161k miles
lostpaul67
GLX Posse - Founder member
Postby Luke » Sun Jun 01, 2008 4:14 pm
int - get your uncle to take the regulator off and SLOWLY crack open the bottle - if there is pressure in there as i suspect then you will hear it come out - then IMMEDIATLY shut off the bottle :!:
there is no reason for the gas to be empty even if you had the regulator turned up full the amount you have used it would still have plenty in - the only way is if you have a leak on the pipes and you leave the bottle open 24/7 :D
Postby intransit89 » Sun Jun 01, 2008 4:24 pm
Luke wrote:int - get your uncle to take the regulator off and SLOWLY crack open the bottle - if there is pressure in there as i suspect then you will hear it come out - then IMMEDIATLY shut off the bottle :!:
i would take the regulator of but the monkey wrench is in daves van so sooner he comes back will try taking it of so it was like i brought and then turn it on to see this was what i was wanting to do :wink: before i think about a refil
intransit89
Postby intransit89 » Sun Jun 01, 2008 4:26 pm
lostpaul67 wrote:How much gas does it take to 'Blow bikes over' :?: :?:
i was saying when i tested the bottle sooner i had it to see if it had any gas in it didnt blow any bikes over :lol:
i was trying to say thats how much pressure was in :!:
intransit89
Postby Luke » Sun Jun 01, 2008 4:27 pm
what happens when you turn the regulator all the way in :?:
