mk5 hi cube 2.5td
Postby MrMPuk » Fri May 05, 2006 2:08 am
Well it's the only bit that moves and every book I have every seen shows this pulley being undone to remove and aslo being used when tensionening!
Postby gemini » Fri May 05, 2006 2:23 am
MrMPuk wrote:Well it's the only bit that moves and every book I have every seen shows this pulley being undone to remove and aslo being used when tensionening!
how do you think you tension the belt on other engines where the pulley dont move at all, most diesel engines the pulley is fixed with a centre bolt on a tapered shaft with a keyway
gemini
Postby AndyG » Mon May 08, 2006 2:41 pm
100ps_drw_hicube wrote:all this talk worries me :lol: im leaving well alone the timing appears fine!!! :lol: :lol: it's definately linked to the epic as it's only smoking when she is hunting!! thanks for all ya help :lol: :lol:
Has the turbo you fitted had any adjustments carried out to it in the past :?:
Why I ask, is now we have an EPIC electronic diagram/info and this could well be why your pump is hunting :?: 'specially as it was alright before
Postby 100ps_drw_hicube » Mon May 08, 2006 2:46 pm
hi mate dont know about the turbo :? :? it has always hunted ever since i owned it but never blew any significant smoke :? :? it could be linked but for some reason i cant view the epic manual so dont know what your on about :lol: :lol: :roll: 572 miles now :shock: :lol: :lol: still going well 8)
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Mon May 08, 2006 2:59 pm
The EPIC manual is in the 'computer related' section. :D
I found it very interesting :D but was dissappointed with the lack of mechanical exploded diagrams :( Never mind we're a bit further with this EPIC :lol: :lol: :lol:
Postby stevew » Mon May 08, 2006 3:03 pm
Also in the useful info section here
:D
Steve
Van Cam, service suspended (no van!) (no cam either!)
stevew
Postby AndyG » Mon May 08, 2006 3:06 pm
stevew wrote:Also in the useful info section here
:D
Steve
CHEERS STEVE :!: :wink:
Postby 100ps_drw_hicube » Wed May 10, 2006 11:23 pm
ye i see the epic manual but for some reason it wont open past the 1st page :? :lol: :lol: anyway off to frauds tommorow new ecu and pump being coded :roll: :roll: will see what happens after then :lol: :lol: for some reason tonite the managemant light came on for 10 miles or so then went off again :? :?
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Thu May 11, 2006 11:32 pm
What did Frauds have to say :?: :lol:
Postby 100ps_drw_hicube » Fri May 12, 2006 3:49 pm
couldnt do it yesterday because they were snowed under with recalled trannys and galaxy's :lol: :lol: :lol: :lol: even tho i was booked in :evil: :evil: :evil: anyway tried rossets (merc truck center) :oops: and they are having the van in tonight and i will have it back tommorow morning 8) £25ish more but hey far more helpful :lol:
100ps_drw_hicube
Transit Abuser!!
Postby 100ps_drw_hicube » Fri May 12, 2006 9:49 pm
:lol: :lol: van aint going anywhere now i cured the black smoke 8) 8) 8) but she still hunts :( i simply disconnected the butterfly loads more power no black smoke and she is a lot better on fuel 8) even better by the end of tommorow :shock: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby tim » Fri May 12, 2006 11:11 pm
Andyg wrote:The EPIC manual is in the 'computer related' section. :D
I have all the mechanical exploded diagrams as well mate.Glad you enjoyed the manual its been under my bed in a box for years now mate
Tim
A WORK OF ART IS A JOY FOREVER
tim
Postby AndyG » Sat May 13, 2006 12:47 am
tim wrote:I have all the mechanical exploded diagrams as well mate.Glad you enjoyed the manual its been under my bed in a box for years now mate
Tim
Really good :!: And from this I think I've worked out why my box changes late since having a new pressure switch :wink:
Any chance of getting the mechanicals uploaded :?:
Postby 100ps_drw_hicube » Sun May 14, 2006 7:40 pm
right went and picked a 4.63 axle up yesterday but got home and realised it was from a srw :oops: :roll: :lol: anyway spoke to mark who said dont try and swap the diffs :( :( but guess what i only went and done it !!.got a hand from a friend was a horrible job but it's in there and works and no whine slight judder on pulling away but other than that perfect :lol: :lol: top speed of 105mph now :shock: acceleration was slightly poo but i had a look at the wastegate actuater and have adjusted it slightly and shes nearly back the same 8) 8) 8) wonder how long the turbo will last tho :? :? :lol: anyway 1020 miles of trouble free motoring so far 8) 8) 8)
100ps_drw_hicube
Transit Abuser!!
Postby tim » Sun May 14, 2006 9:37 pm
Tim
Repair an epic pump.no problem mate with my eyes closed.Upload on the computer,well thats a different story.I will have to get Steve or my six year old grandaughter to help
tim
