new (old) toy
Re: new (old) toy
Postby madmark » Sun Apr 19, 2009 5:40 pm
top work as useual! 8) 8) 8) 8)
Re: new (old) toy
Postby rover » Mon Apr 20, 2009 1:25 pm
Very Very nice Geoff 8) :mrgreen:
Rover.
rover
Re: new (old) toy
Postby transitgeoff » Mon Apr 20, 2009 9:35 pm
well had a result today :D was wondering about the servo and master cylinder, not keen on the worn out mk1 and 2 variants so went into the stores and brought out ALL the variants of servo and master cylinder ford have used on transit from mk1 to mk7, wasnt long before i had a hybrid servo and master fitted 8) , i used the mk1/2 bracket then discovered that a s.w.b mk6 servo has the same configuration of 4 studs sticking out the back as a mk1/2 :shock: so bolted that on, tried shutting the bonnet but the reservoir of the mk6 is huge and fouled the bonnet :x wasn t long before i realised a 1998 smiley master cylinder is a Bosch like the mk6 , well the reservoir only fits and is smaller so dosent foul the bonnet 8) 8) all i had to do then was cut and weld the end of the rod that links the pedal to the servo and it was fitted il add a pic soon as i forgot me camera today :roll: the master cylinder has an outlet for each corner so il be pipeing it accordingly :D
transitgeoff
Re: new (old) toy
Postby MinorMatt » Mon Apr 20, 2009 10:10 pm
Imagine someone in the future trying to work out what M/C is on it! You had better take notes Geoff in case you forget!
Re: new (old) toy
Postby transitgeoff » Mon Apr 20, 2009 10:12 pm
this thread is my notes :wink:
transitgeoff
Re: new (old) toy
Postby redeemer » Tue Apr 21, 2009 7:34 pm
good to let us know geoff..
My mk2 servo, has gone and it has become with a heavy pedal, not in a day but over long time which will be unoticeble. Was going to ask in a new thread but.. Does a mk5 servo fit over the mk2 firewall?? even if I have to do some mods, I can hold a welder
I want a mk5 so the rubber diaphram wont be too old , which will leak.
I may guess that you have access to plenty of parts :P :P
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Re: new (old) toy
Postby winterheating » Sat Apr 25, 2009 7:41 pm
just curious , how much would a mk1 mk2 rotten van be worth with the v4 engine :?:
just i know a guy with a few.
winterheating
Re: new (old) toy
Postby transitgeoff » Sat Apr 25, 2009 8:07 pm
not much to me, im a diesel man :wink: if they had a few bits left on them for me id give about £200 each :D
transitgeoff
Re: new (old) toy
Postby winterheating » Sat Apr 25, 2009 8:15 pm
is it wort taking some pictures, is there anything to look out for interior exterior with these vans that would be worth a bit extra :?: :)
winterheating
Re: new (old) toy
Postby transitgeoff » Sun Apr 26, 2009 7:58 am
definitely take some pics, inside,outside and engine pics :D
transitgeoff
Re: new (old) toy
Postby DOL » Tue Apr 28, 2009 10:32 pm
stunning absolutley stunning Geoff :D
Image 1 by 1 the penguins keep stealing my sanity!!
DOL
Formerly known as Dafodol.
Re: new (old) toy
Postby oldskooler » Wed Apr 29, 2009 9:36 pm
this is an unreal build. quality work. ive already got a mk3 bendix box and ive just found another in a dead ambulance! would i be right in thinking the whole steering shaft from the mk3/4/5 and just the outer column cut n shut?
oldskooler
Re: new (old) toy
Postby transitgeoff » Wed Apr 29, 2009 10:23 pm
yep you would be :D
transitgeoff
Re: new (old) toy
Postby transitgeoff » Sat May 02, 2009 9:53 pm
couple of pics here :D done a bit more, but this is the hardest bit by far, trying to find suitable parts to fit on :roll: spending hours to find a couple of clips or the right sort of bolt and so on :x but anyway ive made some ground 8)
its been a slog, and some of the parts your looking at are still "in progress" ive relined the rear axle, new rear wheel cylinders, new brake fitting kit, new rear shocks (gen ford), new brake pipes completely,new front discs (genuine ford vented 8) )new wheel bearings, new clutch (gen ford), new water pump (gen ford), new cambelt (gen ford), the gen ford parts with discount are only fractionally dearer than pattern and as im planning on keeping it i think the extra is well worth it :!: , ive plumbed the cooling system in, plumbed the pas system, plumbed the brakes, im waiting for my calipers to come back as ive had them rebuilt :D my seats are in the trimmer, and theres still plenty to do but im making ground still :D
transitgeoff
Re: new (old) toy
Postby WINDSCREENGUY » Sat May 02, 2009 10:48 pm
power steering reservior is a bit grubby lol :lol:
formally grey van man.
2010 115 semi high mwb . Fully loaded.
WINDSCREENGUY
previously grey van man
