Well thats been a long winter, its been 4 months since i last done anything, so im going to make the most of some time off.
The cab area was soaking wet, so it was time i did something about it. I removed all the sodden carpet and removed the seats, heater box, glove box and dash panel and it was obvious that the windscreen scuttle was pretty rotten. I had already bought a used scuttle section off a member some weeks back, so it was time to bite the bullet.
Removing the windscreen was pretty easier than i had thought it would be, i just used a screwdriver on the inside and pushed the rubber back inside the lip, worked my round the screen and it just lifted out.
As i expected some bad rot but not the whole of the scuttle, so i only needed to replace a section which made life a bit easier.
I cut out the middle section of the scuttle and ground out the spotwelds to remove the rest. I also had to do this to the repair section which was quite time consuming.
Careful overlapping and marking and the section fits well.
I drilled 7mm holes around the repair panel and plug welded it in place.
Thats as far as i got today, but i got to make good the "A" post and top of the dash and the other small section on the drivers side.
