Robs Green Meanie !!!
Re: Robs Green Meanie !!!
Postby robbie.cee » Thu May 04, 2017 9:20 pm
Got the rivets t'other day so got 3 of 4 done.. of course one wheel is slightly higher one side due to crappy driveway so cant get the rivet gun in as i need a out half inch more gap...
Annoying!!
Sent from my SM-G920F using Tapatalk
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sun May 14, 2017 3:39 pm
Not much done recently but have just cut off a long strip of carbon wrap to possibly use as a windscreen topper .
Found the white ftf window sticker i got for franny but never fitted. Was toyin with that but as its white n blue i think ill save for something else.
Picture to follow soon
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sat May 27, 2017 11:40 pm
Bit of tinkering other night...replaced stereo plugs and wire with the ones from pocket rocket so now i actually have longer than orig loom to allow play. Cb power taken off too so just need run coax to antennae...
Thats all folks
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sat May 27, 2017 11:53 pm
Also now the rear speaker wires arent just shobed into holes in plugs now as i re used the clips from old plug that was previously cut off then i had to hash it all back together with short wire...win win.....herro? [FACE WITH TEARS OF JOY]
Had
MAKE IT FIT
robbie.cee
Postby RustWidow » Sun May 28, 2017 9:24 pm
Good grief, you've been busy!
Sent from my SM-T285 using Tapatalk
RustWidow
Postby robbie.cee » Mon May 29, 2017 10:54 pm
Id have been busier if I wasnt so damn busy all the time (doing non van stuff)
Had
MAKE IT FIT
robbie.cee
Postby RustWidow » Tue May 30, 2017 4:51 pm
Muttley would say the same lol
RustWidow
Postby robbie.cee » Tue Jun 13, 2017 7:26 pm
Actually been playing with van today. Found the missing towbar bolt and sorted that... fixed remote central locking and made the engine fan switch actually light up when on. Bitch still wont start tho after moving her out to re arrange tent and caravan..
Think shes wet her plugs so been messing about finishing all those lil niggling things....
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Tue Jun 13, 2017 7:28 pm
Burner in place cb working even got phone holder with wireless charger!!ImageImageImage
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Tue Jun 13, 2017 7:40 pm
Gonna chop off lower bit between lower and mid bolt holes and once new springs fitted from the 190 should be back up to normal towing height...
And hopefully a lot less axle tramp!
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Tue Jun 13, 2017 7:41 pm
Middle leaves are coming out ...Image
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Tue Jun 13, 2017 7:42 pm
...to replace these god awful abortions...
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Tue Jun 13, 2017 7:43 pm
Lost the bloody battery isolatpr key too so must get another...
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Tue Jun 13, 2017 7:45 pm
Phone charger cradle and cb all in...and the jack plug links phine to stereo for mp3 playback wahoo.
Oh and sub fixed again!Image
Had
MAKE IT FIT
robbie.cee
Postby wronghole » Tue Jun 13, 2017 9:28 pm
Very nice but have got it running yet :?: :?: :?:
wronghole
