My MK5 Minibus Project
Re: My MK5 Minibus Project
Postby RonTransitmk5 » Sun Jan 13, 2013 10:23 pm
Before & after pictures of the Red Oxide, god that stuff is hard to scrub off, I should have worn gloves :lol:
2003 Ford Transit Connect 1.8 TDDI Red.
1999 V reg MK5 Bus(M2) Mid Roof, 2.5di, diamond white. GONE
RonTransitmk5
Postby RonTransitmk5 » Sun Jan 13, 2013 10:31 pm
Leaving it to dry overnight & will then re-do any missed parts, like in the arches on the sides.
Will remove the passenger & drivers seats and red oxide the front floor while I am at it.
How easy/hard is it to remove the sliding door? as need to weld a section behind the sliding bit.
RonTransitmk5
Postby robbie.cee » Sun Jan 13, 2013 11:21 pm
mine falls off if i shut it too fast as it rubs on tires :lol: ... can lift the top runner out of rail, bottom one pops out not sure bout middle one tho !
good shout on red oxiding floor! any left over, get the kids to do underside of van!!!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby johnsvan » Mon Jan 14, 2013 12:56 am
You can take the rail off without removing the door. I did this but cant quite remember the exact sequence.
I think:
Open the door and remove the bolts on the curved bit, then close the door and remove the rest of the nuts on the inside (mine were rusted and I had to cut one off) then maneuver the track off of the door roller. There is some kind of stop and spring action thing as well I think.
I cant remember if I had to support the back corner of the door (on a milk crate and some blocks of wood) or if that was when I needed access for welding.
Anyway, it's doable on your own. :D
Mk5 1999 2.5D 100L high roof
johnsvan
Location: Ware, Herts. (10 Miles north of the M25 on the A10)
Postby RonTransitmk5 » Mon Jan 14, 2013 1:24 am
robbie.cee wrote:mine falls off if i shut it too fast as it rubs on tires :lol: ... can lift the top runner out of rail, bottom one pops out not sure bout middle one tho !
I waxoiled the underside & inside all arches last year when I was doing all the welding :lol:
RonTransitmk5
Postby RonTransitmk5 » Mon Jan 14, 2013 1:25 am
johnsvan wrote:You can take the rail off without removing the door. I did this but cant quite remember the exact sequence.
I think:
Thanks for the info, will have a look later today.
RonTransitmk5
Postby RonTransitmk5 » Mon Jan 14, 2013 1:35 am
Just re-organising pics on my pc & came across these few, does these pics show I have the high spec loom?
Also noticed the metal in the drivers door coming apart, in last pic. will sort when get round to c/l e/w ect.
RonTransitmk5
Postby RonTransitmk5 » Mon Jan 14, 2013 1:38 am
Seriously consisdering getting a doner van, if I can find one at the right price.
RonTransitmk5
Postby MinorMatt » Mon Jan 14, 2013 12:44 pm
Yes, you have the high spec loom
Postby RonTransitmk5 » Mon Jan 14, 2013 5:08 pm
MinorMatt wrote:Yes, you have the high spec loom
Thanks MinorMatt
RonTransitmk5
Postby bobson6 » Mon Jan 14, 2013 9:18 pm
Hi, Any chance of getting a copy of the price list for Unwin? They were meant to send me a copy this afternoon, but recieved nothing and could do with pricing an order up as i need to meet the minimum £30 order
Cheers
bobson6...
bobson6
Postby RonTransitmk5 » Thu Jan 17, 2013 12:40 am
bobson6 wrote:Hi, Any chance of getting a copy of the price list for Unwin? They were meant to send me a copy this afternoon, but recieved nothing and could do with pricing an order up as i need to meet the minimum £30 order
Cheers
bobson6...
Pricelist is in pdf format so cannot attach here, send me your e-mail address & I will e-mail a copy back to you, sent via pm too.
I may manually add the full Unwin pricelist up over the weekend in a new thread for all to see, where would be the best place to put it?
RonTransitmk5
Postby RonTransitmk5 » Thu Jan 17, 2013 12:41 am
Managed to finish the 2nd coat of red oxide today, not done anything else yet as too cold :lol:
RonTransitmk5
Postby robbie.cee » Thu Jan 17, 2013 10:18 pm
m8 i bet the paint was like dough wasnt it? proper cold today!
Had
MAKE IT FIT
robbie.cee
Postby Kestrel » Fri Jan 18, 2013 9:40 pm
Wow Ron, that was some welding job there...a proper project. Good on you for tackling that lot. When I got mine I did the arches and front wings with new body panels (not that they were needed for MOT, just wanted them tidier), only welding it has actually needed was the rear cross member so I guess I've been very lucky from what I've read.
Seats look cool, my kids would have liked something like those.
Regards
Kes
Mk5 2.5 TD 150 swb minibus, semi roof, twin sliding doors.
Kestrel
