- Changed the front springs, the shocks (modified MAN 7,5to shocks)
viewtopic.php?f=4&t=182214- Did the undercoating for this winter
- Let the valve cover seal and the front wheel bearings get fixed
Today I added some solar-panels to the system. They nearly fit my boxes on the roof, except for maybe 1cm. I didn't want them to overlap in front, as trees that are in my way could destroy the panels. So as a result, the panels would overlap on the rear. There for I mounted a rail and also created a protector made from a square cut aluminium, because I found the solar-panel electrics a bit delicate. Trees coming from the front shouldn't be a problem now, but I don't know if for driving in reverse I created more problems... In the end of the day, I also mounted stopper ropes inside the transport boxes, something that's absence annoyed me for quiet a while..
The Solar-System:
1x 130Wp
2x 35Wp
1x MPPT unit
--> parallel setup, with 4x Y-adapters and as a result of the adapting 2 quiet non-conform cables: (+)red female/female and (-) black male/male
I am a bit excited about tomorrow. Then I will see if I connected the panels correctly and if they do their job better than before. Problems that I see are slightly different Voltages of the panels (+/- 1V maybe) and different power output as well as lots of shadows on the big panel for most of the time.
So here are the pics:
