Back to it.
Bought two exhaust clamps today for the joining piece (a bargain £2.40).
I needed to make up some brackets to go on the inner sills to hang the exhaust.
I used a fuel tank bracket from an old bike frame because it has large rubbers,
which will stop the exhaust vibration coming through the bus body -
I chopped it in half to make two, and drilled through the rubbers to insert top-hat-collars.
Then I welded them up to the inner sill, and slapped some underseal all over the place -
Here's the old rusty exhaust
You can see it's completely gone where it joins the front box (or doesn't!)
Tomorrows work will be cutting off the old system, welding up the joining section I made,
bolting up the side-pipe to it's new brackets and clamping the joiner in place
