ztorm wrote:Good job done! Keep us posted bout the power steering in detail! Well, me anyway
Ofcourse I can post some detail
Had to grind out some of the pedal box and custom make up a new mount in the front of the Power steering.
Have dissambled the steering box and cut and modified the steering (rod? not sure what it is named) because of the new parts, the steering wheel mounted directly to the original splines of the Power steering
Modified the top part below the steering wheel so I can mount the original mk1 covers and mk1 flasher/dip switch to the Power steering.
Can take some detail pictures when it is done if you want.
Modified the gearlever also with some homemade stuff on the original gear lever and modified a mk2 gearlever to fit
A lot of fabrication
Ketil
