Mk5 tourneo jag-van mk2
Re: Mk5 tourneo jag-van mk2
Postby DodgeRover » Thu Aug 30, 2018 10:15 pm
Just spotted this megasquirt 3 for sale, nothing to do with me and I don't know the seller but sees reasonable price
http://retrorides.proboards.com/thread/ ... ms3x-cheap
DodgeRover
Postby Pocketrocket » Sun Sep 02, 2018 8:21 pm
DodgeRover wrote:Just spotted this megasquirt 3 for sale, nothing to do with me and I don't know the seller but sees reasonable price
Just left a little post, why do things that are an absolute bargain always come up at the wrong time! :lol:
But yes that would suit my needs perfectly!
Cheers for the heads up!! :wink:
1991 mk3 2.5di county 4x4 lwb ex mini bus camper conversion
1999 mk5 tourneo (previously jagvan, now Vw PD powered now with new owner :cry: )
2000 mk5 with a jaguar twist :wink: (now dead but will live on)
1996 disco 300tdi 1.2 offroad toy :D
Pocketrocket
Postby rob1985 » Mon Oct 22, 2018 8:32 pm
Cracking van mate, just a question about your wheels really, what offset are your front ones? When you said you've redrilled them did you drill for the pcd or the small bolts around the edges? Thanks Rob
rob1985
Postby Pocketrocket » Mon Oct 22, 2018 11:45 pm
rob1985 wrote:Cracking van mate, just a question about your wheels really, what offset are your front ones? When you said you've redrilled them did you drill for the pcd or the small bolts around the edges? Thanks Rob
Hi rob,
The fronts are 16x7j with 0 offset and the rears are 17x9j with a -25 offset. I had to fit the narrower mk3 axle just so that these would go on without them sticking out of the arch.
They were all drilled to to the correct pcd and the old holes welded up, the rears have been drilled around the inside and stainless cap head bolts added so that they matched the fronts too
Pocketrocket
Postby rob1985 » Tue Oct 23, 2018 7:53 pm
Thanks for the info mate, what pcd were they then? 5x165? I've got a mk3 so the rears would fill the arches perfectly! Thanks Rob.
rob1985
Postby Pocketrocket » Tue Oct 23, 2018 10:49 pm
rob1985 wrote:Thanks for the info mate, what pcd were they then? 5x165? I've got a mk3 so the rears would fill the arches perfectly! Thanks Rob.
Yeh they were the landy 5x165,
No worries, happy to help 8)
Pocketrocket
Postby Luke » Wed Oct 24, 2018 7:36 pm
if you mean your van is a mk3 then the rear arches are narrower than the mk5 tourneo so the exact same offset wheels might not fit :idea:
Postby Pocketrocket » Wed Oct 24, 2018 10:48 pm
Good point luke, because of the rolled/wider lip on the mk5s?
May have to go for skinnier tyres to make them stretch under the mk3 arches?
Pocketrocket
Postby rob1985 » Thu Oct 25, 2018 11:41 am
Sounds like a pain in the arse! Do the wheels have to be redrilled then or can you run them on the landy pcd? Might just get some steels banded.
Sent from my SM-A520F using Tapatalk
rob1985
Postby Pocketrocket » Sun Oct 28, 2018 10:34 am
Yeh they have to be redrilled, a lot of people with mk6/7s run them without drilling and get away with it due to them having bigger studs than the mk3/4/5s but Imo it's just stupid!
Safest way is getting them drilled and a 60deg taper for the nut to seat on the rim properly
Pocketrocket
Postby BROWNYS V6 » Sun Oct 28, 2018 11:31 pm
ive read a few comments on faceache, people just bolting landy wheels on, :shock:
BROWNYS V6
Postby Pocketrocket » Thu Nov 08, 2018 12:29 am
BROWNYS V6 wrote:ive read a few comments on faceache, people just bolting landy wheels on, :shock:
Yeh I've objected a couple of time but you just get shot down and the same replies from the same people of "I've had them on for months with no problems"........Yeh thank god your nowhere near my daughters school incase 1 comes off! :evil:
They even give each other tips on how to line the wheel up because the holes arn't in the right place!! :roll:
Pocketrocket
Postby bambi mk 1 » Thu Nov 08, 2018 12:47 am
https://www.youtube.com/watch?v=mJIn6gMlo6A :lol:
bambi mk 1
Postby rob1985 » Thu Nov 08, 2018 7:57 am
Well it's gotta be safe or it ain't happening!! Thanks for all your replies, I'll have a look for an engineering firm who can drill them for me. Luke, if Pocketrocket (sorry I didn't get your name??) Is running a mk3 rear axle will the offset make a lot of difference on my van as it is a mk3? Cheers guys
rob1985
Postby Pocketrocket » Fri Nov 09, 2018 11:12 pm
[/quote]Well it's gotta be safe or it ain't happening!! Thanks for all your replies, I'll have a look for an engineering firm who can drill them for me. Luke, if Pocketrocket (sorry I didn't get your name??) Is running a mk3 rear axle will the offset make a lot of difference on my van as it is a mk3? Cheers guys.[/quote]
You may have to roll your arches to get the same wheels as me under there as the mk3s rears haven't got the flare as such like the mk5s, I've had to roll mine as they catch when there is weight in the rear but I do intend on going to a smaller walled tyre once these need replacing, I'll take a few measurements from mine tomorrow if it's not peeing it down and post em up
Pocketrocket
