If I do do (
ned wrote:I’m not planning on doing it, one sld is enough for me and even that’s a bloody pain sometimes![]()
If I do do (![]()
do do) the drivers side fuel filler I’d probably run the fuel pipe through the van and down through the floor, it’ll probably never happen
Looking good squire, that's some love going into that.loot wrote:ned wrote:Nice how low is the roof chop gonna be 6” are you putting a low roof on or high top/pop top, you know with the donor van you could make a funny van where you cut the middle out.
Quick question are the outer cills spot welded to the inner cill
I'm stitching the low roof on from the tourneo it'll be factory.
I might cut the middle out and fit a pop top. But that's a later project. I've still got loads to do, insulation, tourneo interior,stretch carpet etc, there's a leak from the gearbox to engine seal. I'm interested in fitting a mustang automatic gearbox if possible. Remap possibly. I did have the pcm in it from snowflake but I had to install the original map. I could put a 3.2 pot in it if I wanted. Also I'm interested in upgrading the speedo and adding sync 3. If possible.
It's a long term project and I can get it on the road first.
Panels are all spot welded, they sandwich together. Did you post a picture of your panels anywhere? There's genuine fit ones or repair panels which are different. They're doesn't appear to be factory inner sills available for the non sliding door side
Airthies wrote:Looking good squire, that's some love going into that.loot wrote:ned wrote:Nice how low is the roof chop gonna be 6” are you putting a low roof on or high top/pop top, you know with the donor van you could make a funny van where you cut the middle out.
Re the Mustang auto I can't find any that match the puma bell housing, the Mustang box is for the petrols.
loot wrote:Looking good squire, that's some love going into that.Airthies wrote:loot wrote:[quote="ned"]Nice how low is the roof chop gonna be 6” are you putting a low roof on or high top/pop top, you know with the donor van you could make a funny van where you cut the middle out.
splined flange to either rubber donut or UJ
ned wrote:It’s green, is the carpet dye like the headlining and fabric dye stuff? If it is I’d recommend spraying it on, my daughter used some with a paint roller on the Alfa roof lining and it’s fooking patchy as fook.
ned wrote:I’m no car paint expert but what mix did you do with the lacquer? Will it not flat with 1500 wet n dry
