Van has been off the road for some months while I tidy things up a bit. Cleaned up the engine bay, a lick of paint and sort out the wiring. Pulled most of the ancillaries off to get good access and hand painted the bay, plus repainted a few bits.
Also thought it was about time to fit the headlight washer bottle, pipework and pump. When I fitted the injection metering head, it had to go where the wash bottle was, so I moved the bottle on the other side of the bay. The Mk3 headlight/screen bottle is so much bigger and just wouldn't fit in the space, so I tried a Mk4 bottle, success! Just a little smaller, it fitted reasonably well
Pipework was fitted to grille jets and I couldn't use the reinforcement brackets due to my modified grille, but seemed sturdy enough.
The headlight pump only works when the headlights are switched on, so a relay was wired in.
Sadly, I haven't tested them yet due to my next BIG problem...
