My MK5 Minibus Project
Re: My MK5 Minibus Project
Postby RonTransitmk5 » Fri Jan 25, 2013 11:35 pm
robbie.cee wrote:get the welder out ,Ron. weld a nut onto top of bolt
simples :D
Thanks Rob will give it a go Saturday
2003 Ford Transit Connect 1.8 TDDI Red.
1999 V reg MK5 Bus(M2) Mid Roof, 2.5di, diamond white. GONE
RonTransitmk5
Postby RonTransitmk5 » Fri Jan 25, 2013 11:37 pm
Got a small plate to weld on the passengers side so will try to do this at the same time
RonTransitmk5
Postby RonTransitmk5 » Sat Jan 26, 2013 6:00 pm
simples :D
Cannot weld nut on top as wont be able to get socket on it, so decided to try welding a bolt on top, tried lots of times & every time the bolt just broke.
What am I doing wrong?
RonTransitmk5
Postby johnsvan » Sat Jan 26, 2013 6:34 pm
Doesn't look like you have any penetration. You need to clean the torx up to shiny and use a high current setting on the welder. It's thick material you're welding there.
Also worth shaping the end of the bolt so it sits in contact on both sides.
Mk5 1999 2.5D 100L high roof
johnsvan
Location: Ware, Herts. (10 Miles north of the M25 on the A10)
Postby RonTransitmk5 » Sun Jan 27, 2013 7:21 pm
Got that last bolt out, managed to get me grinder in to take the top off & free the seat, then used mole grips to remove the stud.
Welding, grinding, vactan & finally red oxide.
Will get another coat of red oxide later this week to ensure no bits are missed like I did for the rear.
RonTransitmk5
Postby RonTransitmk5 » Sun Jan 27, 2013 7:30 pm
What shall I do about my disgusting looking mat?
I can jet wash it & leave it in the garden to dry, it will look cleaner but still look crap.
Does anyone sell these new? or anyone got a 2nd hand 1 in very good condition for sale?
RonTransitmk5
Postby swbdave » Sun Jan 27, 2013 8:39 pm
get an offcut of carpet efrom the local cheapo carpet place, use high-temp contact adhesive to glue it on, turn it over then cut off all the excess that is'nt transit shaped :D
jetwash it first & dry it so the glue will go off properly, remember with contact adhesive, spray it on both surfaces, leave it untill its touch dry, then lay the carpet over the cab matt, smoothing out wrinkles as you go, bring it indoors to dry overnight, then cut off excess, worked a treat for me!
Transit 1997 DOHC 2.0 EFI 115PS Pepper Red Metallic Daily driver-Keeper
Transit 1998 85PS turbo diesel automatic van with windows 52k from new needs arches all round daily driver a keeper will be tuning the engine with injectors from Tim
swbdave
Postby robbie.cee » Sun Jan 27, 2013 8:53 pm
bit of carpet or black vinyl ? youll never get a genuine one in any better condition m8! unless you steal andy g s :lol:
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby RonTransitmk5 » Tue Jan 29, 2013 8:33 pm
Thanks for the advice, picture updates
Red Oxide finally finished, 2 coats
RonTransitmk5
Postby RonTransitmk5 » Tue Jan 29, 2013 8:34 pm
Sound Deadening material fitted today
RonTransitmk5
Postby RonTransitmk5 » Tue Jan 29, 2013 8:36 pm
Made sure the front mat was completly dry before reinstalling along with all the trims & seats.
RonTransitmk5
Postby RonTransitmk5 » Tue Jan 29, 2013 8:38 pm
Anyone any idea where this was supposed to go as I cannot remember for the life of me :oops: :lol:
I've had a look about the cab area & cannot see anything missing.
RonTransitmk5
Postby robbie.cee » Tue Jan 29, 2013 8:45 pm
footwell somehere i guess mabey near the not--speakers in footwell?? i guess!? :D
Had
MAKE IT FIT
robbie.cee
Postby johnsvan » Tue Jan 29, 2013 9:05 pm
Hi Ron,
What is the soundproofing you used there?
Does it work?
johnsvan
Postby vanmanloki » Tue Jan 29, 2013 9:07 pm
you've done a cracking job on that mate. doing the floor of my tourneo is next on the list, i just hope it turns out as well as yours.
where did you get your sound deadening material
FORD BUILT TOUGH
1998 Tourneo GLX restoration
viewtopic.php?f=27&t=122620
How to remove a rear floor panel swb mk5
viewtopic.php?f=4&t=127587
vanmanloki
