Ive decided that to save time and money i will paint the body in Dulux Weathershield, i painted my shed doors in it years ago and they still look new. So whats good for the shed is good for the van.
Quartz Flint 2 is the colour and in the tin its looks a nice light grey colour, but on the van it looks much whiter, but hey i bought it now so on it goes!
i needed to paint the front of the luton first so i can still walk on the old bonnet.
At the same time i needed to give the scuttle a fresh coat of paint
Once that was done i could fit the new bonnet, i wet flated it down with 600 grit and gave it a coat of the right colour paint, i only had enough paint for 1 coat. but it has blended in very well.
Now it was time to rub down and primer the passenger side.
I also fitted the other rear lamp holder and wanted to fit the rear step that i had made up last summer.
Trouble is it didnt fit right, it has to lay on the tow bar hitch when down, to support it, and the brackets were to low. All i needed to do was weld a larger piece of angle onto the existing ones and make the hole higher up.
End result is a good fit.
Getting so near the end now i can taste it!
