My mk6 swb
Re: My mk6 swb
Postby Punto443 » Sun Nov 17, 2013 6:37 pm
I got most of my parts from the local scrapyard :D
Took a lot of hunting and a bit of time to collect. :D
I like a bargain and was on gumtree and ebay every night!
I was fairly lucky to find a complete mk7 in the breakers and get in quick! That was a bonus :D
My advise would be read as much on the job you plan to do, and the scrapyards are a good place to see the vans stripped down, without pulling your own apart first :D
Good luck :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby ossie cossie » Sat Nov 23, 2013 1:19 am
nice van. will have questions for you as well. will read the post in more depth later. :D
ossie cossie
Re: My mk6 swb
Postby Punto443 » Sun Dec 01, 2013 8:25 pm
Quick update: I've removed the rear seats as it just wasn't working day to day for me, started fitting the heated seats, then........ The pump packed in! Had to get towed of the M8 by my mate in his little berlingo :lol:
Up and running again thanks to the guys on here :D
Pump was a bast@rd to bleed up :?
I'll get some pics of the seat mods later.
And I need to line up the front panels properly after stripping them down
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby karl » Sun Dec 01, 2013 8:47 pm
tell me about it just done a job put a brand new pump on and couldnt get it going even using the method some people use here
ended up towing it for less then a quater mile job done
:arrow: viewtopic.php?f=5&t=138259
karl
Tranny Lover!!!
Re: My mk6 swb
Postby Punto443 » Fri Dec 06, 2013 6:30 pm
Woohoo :D Passed the mot, no sweat!
Now back to the fun stuff :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby dieselhead123 » Fri Dec 06, 2013 6:38 pm
Good on you mate!
I bet you are a 'Happy little Punto' :lol:
Re: My mk6 swb
Postby Punto443 » Fri Dec 06, 2013 6:40 pm
Damn right I am :D :D :D fully road legal again!
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby Punto443 » Fri Dec 06, 2013 6:41 pm
And hopefully by the end of the weekend I'll have a nice warm seat to sit on :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby Punto443 » Sat Dec 07, 2013 12:53 pm
Some pics of my work to the seats :D
Pumpy up lumber adjustment fitted
Heat pads fitted
Wiring for switches fitted
And finally the switches mounted in the modded pod :D
I've still got to fit the aux fuse board behind the drivers seat and just wire the relays.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby limitedblack » Sat Dec 07, 2013 3:41 pm
Bzzzzzzzzzzzzzzzz :o :lol: ;)
Happy Easter
limitedblack
Re: My mk6 swb
Postby JmeRaynor » Wed Dec 18, 2013 7:43 pm
Here's a question for you punto, how did you get the mk6 instrument cluster to fit into the instrument panel, the sides seem to wide to slide into? what did/didn't yo chop to make it fit?
JmeRaynor
Re: My mk6 swb
Postby Punto443 » Wed Dec 18, 2013 8:01 pm
I had to cut sections out of the dash at the sides to get the speedo head in and the used heat gun on the front Fasia and stretch the sides out and match the shape :D
Worked out not to shabby at all :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: My mk6 swb
Postby JmeRaynor » Wed Dec 18, 2013 8:40 pm
Yea it looks smart from the pictures, Ill have a crack at it tomorrow
JmeRaynor
Re: My mk6 swb
Postby looneyfitter » Wed Dec 18, 2013 9:38 pm
Great work there mate love it ;-). Any pics if with the rear seats fitted? Did you manage to get triples in and how wide is the side cabinet for the 8x4's?
Thinking of doing summit similar but can't decide whether to do raised floor or the side cabinet??????
Cheers
I WILL GET THIS FEcKER RUNNING!!!
looneyfitter
Re: My mk6 swb
Postby Punto443 » Wed Dec 18, 2013 11:42 pm
The rear seats were removed after about 6months, I had a twin seat fitted and it still left about 18" of load space behind the drivers seat. But I found it didn't justify the compromise in load space for the odd occasion it was used :?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
