Kristianskaffe's MK7, 2.4 TDCI, RWD
Re: Rear brakes MK7, 2.4 TDCI, RWD (and a general question)
Postby Kristianskaffe » Tue Mar 28, 2017 10:29 pm
Airthies wrote:
Kristianskaffe wrote:Crap.. Or what to say..
All 5 wires test OK. Suppose, that's a good sign.
Everything is beeping as it should.. So now I'm in the dark again.
Any good suggestions on what to do now?
Only thing I may suggest is that when testing each wire for beep tone. Shake the bunch of wires going from body to engine to make sure it's not partly broken and made worse with movement?
Also if when testing (depending on your meter) it may give you a reading or change to check for resistance (like that symbol but without bottom line). They should all read roughly same (next to nothing) but if for example maybe the one sending signal to pcm is higher than rest it may cause pcm to think unit is in a position different to where it should be and so the readings pcm is getting are out of it's range so it says it doesn't know where it is?
But if you can get an actuator that would help eliminate any doubt there hopefully before going back into the wiring.
Your doing yourself proud with what your dealing with. Keep at it mate. I'm glad I never gave up on mine when it was causing trouble it's been worth it for us.
heehaw tae see here, please shift along.
Thanks a lot :) Yeah, way too late to turn back now :D
But I feel I have an OK van, if this gets done. Why should it not :)
And maybe I have no problems for the next 2 years and then it was all worth it.. :)
http://www.kristianskaffe.dk
Follow me here and see what I´m fooling around with :D
https://www.instagram.com/kristianskaffe.dk/
2006 Transit undergoing makeover and refurb :D
Kristianskaffe
Postby Kristianskaffe » Thu Mar 30, 2017 2:50 pm
Egr received. Planned to go in next week.
Just ordered a new right hand side mirror, as I kissed a tree this morning in a very tight and narrow passage.. Just barely hit it, and I couldn't even tell where I hit it.. But the mirror just fell to the ground and went into bits and pieces... Crap..
Kristianskaffe
Postby Kristianskaffe » Fri Mar 31, 2017 8:35 am
This just in
Kristianskaffe
Postby Airthies » Fri Mar 31, 2017 8:40 am
Kristianskaffe wrote:This just in
Oooh, shiney
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Kristianskaffe » Fri Mar 31, 2017 8:42 am
Kristianskaffe
Postby loot » Fri Mar 31, 2017 8:50 am
That's not the egr :D
Ids map here
loot
Postby Kristianskaffe » Fri Mar 31, 2017 8:53 am
loot wrote:That's not the egr :D
Maybe that explains my trouble.. I was wondering how to fit in by the manifold ;)
Egr landed at the mechanic today, along with srv and prv. Power steering pump is in Sweden but should land monday.
Just got hold of the guy who sells the rear doors, so picking them up today.
One of the has now glass in window, so I need to transfer mine.
What do I glue it on with? Silikone?
Kristianskaffe
Postby loot » Fri Mar 31, 2017 9:26 am
You are meant to use the bonding kit,
http://m.ebay.co.uk/itm/ONE-SCREEN-WIND ... iid%253A17
Ids map here
loot
Postby Kristianskaffe » Fri Mar 31, 2017 9:28 am
loot wrote:You are meant to use the bonding kit,
Crap.. Hoped i could get it done this weekend..
Well, have to clean them and get the vinyl off before anyway..
Thanks!
Kristianskaffe
Re: Kristianskaffe's MK7, 2.4 TDCI, RWD
Postby Kristianskaffe » Fri Mar 31, 2017 2:11 pm
Well.. I think in the heat I might have missed a pretty simple test..
I have unplugged the MAF sensor and now I don't have the overboost from the turbo. It drives much much smoother and it seems to make lot less black smoke.
I still get that the turbo is mechanically stuck when testing it. I'm really not positive about the EGR causing that... But I can hope for it...
So now it seems I need a new MAF... I'm happy I didn't buy a newer one.. I would have missed all this fun ;)
Back doors is now in da house! :)
Last edited by Kristianskaffe on Fri Mar 31, 2017 2:12 pm, edited 1 time in total.
Kristianskaffe
Ha.. Finally I got a new subject to this mess of a thread
Kristianskaffe
Postby Kristianskaffe » Fri Mar 31, 2017 3:39 pm
Now I just need to get the adds off :)
Kristianskaffe
Postby Airthies » Fri Mar 31, 2017 4:28 pm
Its not a mess its an impressive documentation of yours and others efforts in resolving faults and overcoming troubles!
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Fri Mar 31, 2017 4:29 pm
Kristianskaffe wrote:Image
Heat gun! Then brake cleaner
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Kristianskaffe » Fri Mar 31, 2017 4:32 pm
Ha.. On was on to that
Kristianskaffe
