New Sub Box...
My lash-up thin ply box is even flappier than I was expecting, but have since been given some 18mm MDF.
I'd like to make the new box double-walled, but the internal size would end up way too small in my available space,
so will just fit plenty of internal bracing instead.
I'll get some pictures of the build of the new box on here when I get round to starting it.
TransitMania 2010 Sound-Off ...
I found I had one sub not working on the Friday evening installation, but solved that problem eventually.
I lashed up the blown fuse on Saturday by cutting the top off and wedging a gold terminal connector into it
Sorted.
Ran the sound-off without any prior testing and got a 113 point something dB, I think
so right down on last year, but different meter, so assume mine was well out of calibration last year
Next problem
Sub amp kept cutting out on the way home due to major overheating.
It's running at 1ohm and in very restricted air space, so not at all surprising.
I have some cooling fans to install in the amp panel, which I should have fitted a long time ago,
but will definitely do that soon now!
Also I wired the subs bridged this week while I was trying to find the wiring problem,
so will change that back to 2 channel now so it's 2 ohms. It'll be easier on the amp.
The signal is mono'd at the sub xover anyway, and there's more than enough volume.
Generally ...
Been really enjoying the new and improve sound quality, but still want more kick from the midbass.
They're JL six inchers I've put in the new centre console, but I also have some Rockford 6's tucked away,
so plan to add those on the door bottoms now, by the footwell mounted mids.
Again, will post pics when I do them.
