ned wrote:I quite like the look of those roof pods, do the lights come with them?
Are you planning any Kelsa light bars along the cills ect
ned wrote:I used to use 2000 wet n dry then 2500 then 3000 then machine polish with some 3m cutting compound, it’s a slow process but worth the time you put in, best thing I found was working small section at a time like the front wing and once happy with that move onto the door and so on, a bit of washing up liquid in the water helps the sand paper work better.
How much orange peel have you got in the paint?
Airthies wrote:Looking good there fella.
Be done in no time
Sent from my Pixel 8a using Tapatalk
ned wrote:Ffs loots been around to mine and painted my daughters car race red![]()
That roof lining looks miles better with the stretch carpet on it, you’ll be doing the door cards next or is that just me.
Where did you get your paint from and is it a true match?
ned wrote:Are the rear seats on unwin rails or just the tourneo latch thingy, I see your dilemma you can buy aftermarket cab carpet in black but no sure on the rear carpet, personally I wouldn’t try and dye the carpet as it always looks crap and patchy I know as my daughter did it in the Alfa, can you not glue stretch carpet over the tourneo carpet just a thought, it’ll be a nice looking van when finished, I suppose leaving the door cards to match the carpet might look better, I’ve covered on card with carpet but no sure whether to paint the plastic around the window switches and handles black, suppose I should fix’s the brakes and gaping hole on the passenger door cill first![]()
It’s only the bonnet and spoiler that needs paint on the cheap fester might see if I can it colour matched
