I am still planning on getting some electric ones soon
gotgcoalman wrote:Is it upside downloot wrote:And find some stronger struts in the hedge
I just ordered some news chinesium struts from ebay for £10, bargain and will be quality of that I'm sure.
Speaking of Internet junk, temu steering wheel leather grip turned up.with needle and thread
Only took an hour and cost £3.50
Not perfect and didn't spend my life on the threadwork but I'm happy with it.
Sent from my LE2101 using Tapatalk
Altransit wrote:loot wrote:does anyone remember tailgate gate? @punto443 @tango
I think there's only a couple on here that recall but @Altransit should recall. Anyway we were in a tailgate club sort of thing and bought uprated tailgate struts. I never fitted them to my van in the end circa 2012 ish.
Oh I recall all right![]()
I've never understood the need for one on a panel van, my vans were always loaded right up to the doors, and a tailgate would enable the escape of goods onto the road when opened. It's much easier for me to crack open a rear barn door and catch any falling debris before it makes a bid for freedom![]()
I've also whacked my head on far too many tailgate edges to be a big fan, some of them only seem capable of opening to 90 degrees
MinorMatt wrote:Altransit wrote:loot wrote:does anyone remember tailgate gate? @punto443 @tango
Great to keep the rain off when working at the back
Airthies wrote:Just need to make sure of the closed length in case of binding when the tailgate is being shut.
Simple way to measure is put a small cable tie around the rod when open and let the cylinder push it up the rod as it closes.
Open the tailgate and measure from the centre of the ball end down to the lower side of the cable tie, then from the centre of the cylinder ball to the rod end of the cylinder (that pushed the cable tie) and add those two measurements together and you've got the maximum closed length of strut that you can fit.
Simples
Sent from my Pixel 8a using Tapatalk
Airthies wrote:It could be that they are similar size but different stroke length.
BJT could have schooled you more on stroke length but GCM may well have similar knowledge
loot wrote:
I really should have looked closer to my original strut in the beginning for the seemingly obvious part numbers I could have googled
You mean to say I wasted all my time and knowledge on something that could have been solved by the application of "having a better foofing look"
I suppose, they're are worse people to waste time onloot wrote:Airthies wrote:loot wrote:
Yes perhapsbut consider this... It was lovely chatting with you
