They are fixed
with the leafs alone the van would be on its arse - rememberlincolnrs2 wrote:How can they adjust in height then mate cause the leaf springs ar'nt adjustable![]()
They are fixed
custom wrote: with 2 leaf springs removed
Luke wrote:with the leafs alone the van would be on its arse - rememberlincolnrs2 wrote:How can they adjust in height then mate cause the leaf springs ar'nt adjustable![]()
They are fixed
if you add the springs in the coil overs it will raise it to the level req'd - adjust the platform to make it what you want
i might do my van one day, i'll totally remove the leafs tho
sounds like a plancustom wrote:so ive decided to get some new coilovers from burton power as they sell them in different lenghts then im going to make some brackets and put anti tramp bars on and do away with the leafs altogether, had a look at how its done on an escort mark 2 and a transit doesnt look much different
Luke wrote:sounds like a plancustom wrote:so ive decided to get some new coilovers from burton power as they sell them in different lenghts then im going to make some brackets and put anti tramp bars on and do away with the leafs altogether, had a look at how its done on an escort mark 2 and a transit doesnt look much different- i would leave the leafs there untill you have all the brackets in place - it will keep the axle while you are doing the work
you need to make sure the distance between the 2 holes top and btm of the axle are the same as the ones on the body! it's a pity you couldn't make it to the last meet - i could have chatted about this, its still on my wish list![]()
remember the transit is much bigger than a mk2 escort so get the bigger rosejoints
you could do that but what you need to do is keep the axle angle the same as it moves up and down if you dont have 4 brackets you'll end up with the angle changing as it goes up and downcustom wrote:youve lost me on the whole 2 holes bit mate what do you mean?
i intended to make a metal plate up with the holes in the same place as the u bolts then weld a u bracket to that to mount the bars to and the other end of the bar i was gonna mount in the lear spring mount on the van that way i could use all the original mouting points on the van
goody wrote:hi goody here,(WG racing,van)
i did this to my van a couple of years ago before i put on big wheels,you might get away with this custom because of your arches, gas axe 2 axle mounting brackets of another axle, weld them on the bottom of your axle opposite the originals then put the axle on top of the leaf springs with u brackets the opposite way around, uprated shockers will do , if botherd u can shorten the compersater valve spring never had a problem with the rear just the front being to low
