good job i did it yesturday. its f*****g snowing now
Andyg wrote:You just need a set of blue dot injectors and a 145/6 pump![]()
Nice job on the wing![]()
When are you painting it Diamond White![]()
Andyg wrote:Did you take your time and make the welds look factory![]()
Guy88 wrote:also had my electric fan relay fill with water and the fans stayed permanently on
Andyg wrote::? But isn't this pump going onto a N/A engine that a turbo has been added and not a "low compression" turbo engine![]()
So the timing is only artificially set on a turbo engine with a Bosch pump who's EPIC has been removed
