Mk5 recovery project
Re: Mk5 recovery project
Postby noah » Mon May 27, 2013 3:17 pm
good work horse that
noah
Postby Gtitom » Mon May 27, 2013 11:25 pm
Thanks!
Picked up my new front hubs and wheels today.
Also got the large cab interior mat as it didnt come with any when i bought it.
New stereo and have got some brand new 6x9 speakers to fit in the doors.
New winch solenoid
Wireless winch remotes
Treating it to some love atm, still need to do a cambelt as every long journey its on my
Mind..
Gtitom
Postby dieselhead123 » Tue May 28, 2013 7:28 am
A lot of good work going on there mate.
Can I ask about the axle swap you did?
Are the single and twin rear wheel axles the same width?
Did the replacement fit the existing rear springs?
Was everything else, brake flexy, compensator, etc. in the same place?
We have one here that will be getting swapped the other way, twin off, single on.
Thanks,
Postby Gtitom » Tue May 28, 2013 12:34 pm
dieselhead123 wrote:A lot of good work going on there mate.
Thanks,
I didnt have the single and twin axle side by side to measure the difference but im pretty sure the twin axle is shorter hub to hub.
The leaf springs are the same, but the leafs need to be mounted closer to the chassis, so you need the twin axle leaf mounts, in your case you will need the single axle chassis mounts.
Everything else was a straight fit!
Gtitom
Postby dieselhead123 » Tue May 28, 2013 2:09 pm
Cheers, thanks for the info.
We are fitting a single wheel rear axle, with the wheels, to a truck so as to use the flareside body.
Any chance you still have the parts you removed from your truck?
Thanks again,
Postby robbie.cee » Tue May 28, 2013 9:51 pm
Gtitom wrote:Thanks!
New winch solenoid
Mind
naughty!! :roll: get it changed m8 its the worst thing that could happen especially if it were on way to a pick up!
new belt, tensioner and water pump should be next on your shopping list!
that motors lurvely , look after her!!!! 8)
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Gtitom » Tue May 28, 2013 10:47 pm
Dieselhead - i scrapped the brackets along with the old leafs, i did consider keeping them but didnt think anyone would want to convert the other way round!
Got the front hubs and wheels swapped over earlier aswell, ive ended up with a 185/15 and a 195/15 which is annoying but should of checked when i bought!
The cam belts on the list of things to do, should be at the top really!
Gtitom
Postby Gtitom » Tue May 28, 2013 10:49 pm
Gtitom
Postby dieselhead123 » Tue May 28, 2013 10:56 pm
Gtitom wrote:Dieselhead - i scrapped the brackets along with the old leafs, i did consider keeping them but didnt think anyone would want to convert the other way round!
Thanks for looking anyway mate, the info is useful, at least I know what I have to look out for now.
Thanks,
Postby karl » Wed May 29, 2013 8:07 am
looks miles better with those hubs on :D
karl
Tranny Lover!!!
Postby Gtitom » Wed May 29, 2013 7:24 pm
Got the interior sound matt fitted along with a passenger doorcard, and some sound matt on the rear of the cab, should have done this a long time ago! So much nicer to drive and its quiet!
Also got my 6x9s in the front doors.
Gtitom
Postby Gtitom » Sun Jun 02, 2013 7:46 pm
Got the rear wheels painted today looks loads better, just need to sort the fronts out now.
Gtitom
Postby Gtitom » Tue Jun 04, 2013 7:30 pm
Front wheels done.
Gtitom
Postby Langballen » Tue Jun 04, 2013 7:44 pm
Gtitom wrote:Got the interior sound matt fitted along with a passenger doorcard, and some sound matt on the rear of the cab, should have done this a long time ago! So much nicer to drive and its quiet!
Top job the, mate...
What brand did you use for the sound matts?
MK5 smiley: '96 150L LWB semi high, 2.5 D non-turbo (yet), 76 PS, MT75 gearbox, 6 Stud wheels 15"
If it ain't rusty - it ain't a Tranny
Langballen
Postby Gtitom » Wed Jun 05, 2013 12:07 am
Heres the link to the sound mat i used, luckily i got it for free!
https://www.europaspares.com/product/0/ ... heets.html
Gtitom
