3/8" Drive Torque Wrench
Torque Range - 5 < 80 Ft Lbs
would this torque wrench be ok for doing timing belt as i only know it in nuetons this is in foot pounds ??????????
johnsvan wrote:Will be fine.
Just use a online calculator to convert:
http://www.boltscience.com/pages/convert.htm
johnsvan wrote:Don't know where to get them from, I just made my one.
I don't see the point of removing it altogether, my engine looks as standard because I just slipped my blanking plate in between. That's the way I like it - no questions from the MOT guys.
If you do buy some then make sure they are strong enough to be used without the EGR pipes and flanges otherwise you will have leaks.
