Gaz's Mk3 truck
Re: Gaz's Mk3 truck
Postby Mr RVM » Wed May 08, 2013 12:40 am
Didnt get much done today, have no transport at the min so had to use the bus which takes ages and had to quit early to make sure i got back :( but anyway this is the piece i cut out of the top of chassis rail inside cab....
and now i've got the inner reinforcement fitted.....
made this again from 2mm steel bent to 90 degrees then fitted them together so the top face is 2 + 2mm so when outer skin (again 2mm) is fitted the total thickness will be 6mm (about the same as original)
Roll on sunday hopefully get this bit finished :)
Mr RVM
Re: Gaz's Mk3 truck
Postby Mr RVM » Tue May 28, 2013 7:21 pm
Not much progress to report lately too much other stuff goin on :( , after a good look at things over the weekend i've come to the conclusion that this old truck wont be ready for the mania and i'm absolutely gutted :( :( :( i considered rushing things and maybe cuttin a few corners but then decided that having put so much into it i couldnt now start tryin to hurry things and make an arse of it :!: in the meantime i have got hold of a little flareside truck that needs a bit of TLC (quite a bit in fact) will have to start another progress thread on this one but should be a much quicker job to get it tidied up for August, not too bothered about keepin it so original, just upto mot standard and a bit of cosmetic work should have it looking ok so thats where my effort will be spent for the next few weeks :!:
Mr RVM
Re: Gaz's Mk3 truck
Postby Luke » Tue May 28, 2013 10:09 pm
you do right not to rush it :!: quality work takes time 8)
Re: Gaz's Mk3 truck
Postby Mr RVM » Fri Jan 03, 2014 10:15 pm
Nearly 8 months since i last did anything to this but as well as the Flareside i've set away with this one again and again i'll get some pics up over the weekend :!:
Mr RVM
Re: Gaz's Mk3 truck
Postby celtic0125 » Fri Jan 03, 2014 11:07 pm
Fuk me big job that mate glad mine is in mint con thow no rust any where . Will u be takein it transitmaina this year mate
celtic0125
Re: Gaz's Mk3 truck
Postby Mr RVM » Fri Jan 03, 2014 11:16 pm
That was the intention last year but for a million reasons it didnt get done so just kicked it off again and hopefully this August...........................
Mr RVM
Re: Gaz's Mk3 truck
Postby celtic0125 » Fri Jan 03, 2014 11:39 pm
Ye man mite c u there then mate keep me posted and if u need any parts let me know
celtic0125
Re: Gaz's Mk3 truck
Postby Mr RVM » Thu Jan 23, 2014 4:07 pm
Got some work done lately hopefully a lot more over next three days
Used a high zinc anti rust primer (the brown stuff) then red oxide and will give the whole lot a coat of light grey to give a nice even undercoat for the Yellow topcoat :!:
Mr RVM
Re: Gaz's Mk3 truck
Postby Mr RVM » Sun Jan 26, 2014 9:59 pm
Bit more done today.....and this is it in the grey.....
I decided to give the arches a coat of Hammerite "smooth" in white (i got hold of 2x5 litre tins for £30 so will have to use it :lol: ) thought it would be a good tough undercoat and it should bring out the best in the Yellow topcoat :!:
thats it for now, back to work for 8 days on the trot so wont get up there much :(
Mr RVM
Re: Gaz's Mk3 truck
Postby transitandy » Mon Jan 27, 2014 10:57 pm
Great thread m8y :)
Re: Gaz's Mk3 truck
Postby Kedishen » Mon Jan 27, 2014 11:38 pm
Cracking job. Golden yellow - is that the same as JCB yellow? Best put a mini digger on the back for that extra finish :D
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
Re: Gaz's Mk3 truck
Postby Mr RVM » Mon Jan 27, 2014 11:48 pm
Kedishen wrote:Cracking job. Golden yellow - is that the same as JCB yellow? Best put a mini digger on the back for that extra finish :D
I think its close to plant yellow but a bit warmer if you catch my drift :?:
Mr RVM
Re: Gaz's Mk3 truck
Postby Mr RVM » Thu Jan 30, 2014 1:02 am
Went up tonight after work for an hour and painted under the arch in its final colour so this is it in the YELLOW :D brighter than i thought but looks clean and BRIGHT :!:
Hope to get the whole front end done soon so its got plenty time to harden before i start to fit all the stuff back in :!: :D :D :D
Mr RVM
Re: Gaz's Mk3 truck
Postby Kedishen » Thu Jan 30, 2014 1:30 am
Did you buy that paint from delboy? :lol:
Kedishen
Re: Gaz's Mk3 truck
Postby TIMO » Thu Jan 30, 2014 1:40 am
thorough job there mate :D
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
