jd-lee wrote:I like a lot bud. Keep up good work
Orangeboogie wrote:Hi Ben van looks gd mate! Tell me did u colour
Code the arches and put them on?
Big Ben 83 wrote:jd-lee wrote:I like a lot bud. Keep up good work
Thanks.
Your's looks cool being dark. Your top markers, was the wiring there like on the pickups? I've got some but not got round to fitting them yet.
ake wrote:Big Ben 83 wrote:jd-lee wrote:I like a lot bud. Keep up good work
Thanks.
Marker wiring is only on chassis cabs, not fitted on vans
Thanks.
jd-lee wrote:Big Ben 83 wrote:jd-lee wrote:I like a lot bud. Keep up good work
Thanks.
Cheers mate. At the top of ur A pillars u have the wiring going to rear lights. I just found the sidelight wire and broke into that. Did u buy new roof markers. If so cause the foam pad is new when u fit them u can bolt them down how there meant to be and the foam creates the water tight seal. Remember the light trick... Swap the left with the right and right with the left. Cause their shaped to the bulge on the tippers roof. Swapping the lights round finds a rough shape for the light to sit on the roof and when bolted from inside it pulls the light and roof panel together.
