Thanks to the weather I got a good bit done again today.
I finished off the spring hanger on the passenger side in the same fashion as the driver's side. This was much easier because I had all the measurements to copy from the driver's side so it went together much faster. I also cut back the chassis to the engine mount again because it was quite crusty.
Once I had both spring hangers in position I dragged the IFS round from where I had it stored and bolted the front of it in. After removing the bump stops from the chassis I jacked it up to see what it looked like.
Again I had the engineering firm make me a set of folded pieces for this purpose. These slide nicely over the chassis ready to be welded all the way around.
I wasn't too sure if it was sitting correctly so I just tacked it in place on the driver's side and used a G clamp to hold it in place on the passenger side for now. So the front IFS axle is now hanging by itself under the van. It felt great to step back and look at this after so much hard work! The front crossmember still isn't welded in place though - I just keep using it for reference to make sure everything is still lining up at this stage.
The question I have, though, is does this look normal?
That's as tight as I could get it jacked up to the chassis at the front of the bracket. I had to notch a hole in the chassis for the captive nut to protrude through.
How do I tell if I've got this in the right position before I weld it up completely??
