Quite a few accessories have gone in, phone chargers, camera leads, etc. Still waiting on rfid ignition system so I can finally finish all the under dash wiring. I was trying to go totally keyless - no door key, no ignition key. Unfortunately the door lock system wouldn't play ball as it was too hard to be operated by the central locking motors I put in. So I dug it out and tried to shorten the springs inside which kind of ruined the lock system. Well I put it back in the door as I had to close the door somehow. The door opened and closed easily, so ruining it made it work better. I still couldn't work the lock unlock in it so I used a solenoid to simply pop open the door. I disconnected the door handle and the key lock so now the door is popped open using the alarm keyfob.
Solar panel is in to trickle charge the batteries. This is a long term plan as I intend to export it eventually in years to come to a sunnier climate where it may be parked for long periods of time unused. Replacing batteries can be expensive so this way, it should keep the battery topped up and not allow it to get low enough to kill it.
Speaking of batteries I bought some huge 800CCA leisure batteries £50 each from ebay, with a 4 year guarantee (not sure if it's worth the screen its printed on but..).
They are too big to fit under the hood where they are supposed to be so there will need to be some adapting or relocation to make them fit.
I'm going to wire in the marker lights and flashers around the chassis as soon as it stops raining, the its on to the bodywork. Once that's done, i'll put the seat covers on permanently on the seats then install the seats and it will be MOT time. If it passes then i'm going to do a weigh-in so I can get the weight of the truck. I can start to see a flicker of light at the end of the rusty tunnel.
