Loots Red custom
Re: Red
Postby Altransit » Sat Aug 06, 2016 6:45 pm
loot wrote: we're special 8) :lol:
Tell me about it :P :lol: :lol:
Re: Red
Postby bigjohnthomas » Sat Aug 06, 2016 6:50 pm
the lime has a single fan too had it in 47 degrees outside temp and all nice n cool inside
2 fans are for pussies :wink:
bigjohnthomas
Re: Red
Postby loot » Sat Aug 06, 2016 6:55 pm
:lol:
Do you think the extra fan was like the filter mounted lift pump?
Kind of an after thought because the egg heads in the technical department ballsed up the maths? :lol:
Ids map here
loot
Re: Red
Postby bigjohnthomas » Sat Aug 06, 2016 7:04 pm
like having 2 bolloks you only use one but it looks a bit empty without 2
bigjohnthomas
Re: Red
Postby Altransit » Sat Aug 06, 2016 7:18 pm
Well, so far I had worked out that the low spec low power vans only had one fan, and the higher spec higher power had two, but if Harry the limited lime only has one, then that theory is out of the window :?
Re: Red
Postby bigjohnthomas » Sat Aug 06, 2016 7:43 pm
I have had to check now ..
defo just one fan
bigjohnthomas
Re: Red
Postby loot » Sat Aug 06, 2016 8:21 pm
On a slightly different note, i went into config today and apparently i have rear glass :lol: it must be behind the metal them :shock:
Ids map here
loot
Re: Red
Postby bigjohnthomas » Sat Aug 06, 2016 8:31 pm
will one be fitting glass in there ?
bigjohnthomas
Re: Red
Postby loot » Sat Aug 06, 2016 8:59 pm
bigjohnthomas wrote:will one be fitting glass in there ?
I have a million things i want to do but at the moment I'm concentrating on getting it on the road :-)
Been looking on eBay for more bits i need, 2 seatbelts, driver airbag and passenger airbag or cubby.
Hens teeth and very expensive :?
Ids map here
loot
Re: Red
Postby bigjohnthomas » Sat Aug 06, 2016 9:31 pm
yeah time and money are always the enemy :x
bigjohnthomas
Re: Red
Postby loot » Sat Aug 06, 2016 10:10 pm
Ah i think you missed the point, they're trying to get upto 250 for a custom steering wheel airbag :roll:
Ukoff mate so what if they are newish, they're no different from a slightly older 1 for 50 quid (production value) it's not a brand new vhs video recording device is it :?
Money for the sake of it imo, i can buy an airbag cover for 80 pounds tho :shock:
Ids map here
loot
Re: Red
Postby Altransit » Sat Aug 06, 2016 10:26 pm
Those are the rules of supply and demand, the newer and more desireable a product, the more it will change hands for. If you're content with older technology, or a less desireable product, then you can often buy it for much less. Your choice really :mrgreen:
Re: Red
Postby loot » Sat Aug 06, 2016 10:38 pm
I agree, it's the way it it unfortunately :-( i wonder if it would be cheaper from Ford tho? Everything else has been :lol:
Ids map here
loot
Re: Red
Postby bigjohnthomas » Sat Aug 06, 2016 10:40 pm
yes missed the point spesh brew and pokemen taking their toll :oops:
used to work up near hills for a decade got to know a lot of the traders most of them wouldn't worry about a bloody air bag
just put a cover on it larr calm down calm down gizza lemo
bigjohnthomas
Re: Red
Postby ake » Sun Aug 07, 2016 8:50 am
Altransit wrote:Well, so far I had worked out that the low spec low power vans only had one fan, and the higher spec higher power had two, but if Harry the limited lime only has one, then that theory is out of the window :?
I reckon it's heavy high power air con vans that get two fans
