My big project Recovery MK4 to MK5 Di to TDi
Re: My big project Recovery MK4 to MK5 Di to TDi
Postby Stule » Thu May 31, 2018 6:37 am
Inside finishing fast forward
Stule
Postby Stule » Thu May 31, 2018 6:41 am
Inside going
Stule
Postby Stule » Thu May 31, 2018 6:46 am
Time has come to work on front end because it was rotten to the end i cut whole front end and cuted a good front end from donor mk5 which was in good condition
Stule
Postby Stule » Thu May 31, 2018 6:53 am
Front end from donor welded to recovery mk4
Stule
Postby Stule » Thu May 31, 2018 6:59 am
Front end welding and grinding and again welding
Stule
Postby Stule » Thu May 31, 2018 7:04 am
Going for some fillers
Stule
Postby Stule » Thu May 31, 2018 7:07 am
Anti stonechiping...
Stule
Postby Stule » Thu May 31, 2018 7:13 am
Sealing,filling etc
Stule
Postby Stule » Thu May 31, 2018 7:17 am
Working...
Stule
Postby Stule » Thu May 31, 2018 7:22 am
And going...
Stule
Postby Stule » Fri Jun 01, 2018 6:26 am
New wings welded, firewall primered then 2 coats of underbody anti stone chip black
Stule
Postby Stule » Fri Jun 01, 2018 6:29 am
Started masking off preparing for first coat of epoxy primer
Stule
Postby Stule » Fri Jun 01, 2018 6:33 am
Still masking...
Stule
Postby Stule » Fri Jun 01, 2018 6:36 am
Finished masking ready for first coat of epoxy primer
Stule
Postby Stule » Fri Jun 01, 2018 6:47 am
This is finished priming ready for paint. The steps were:
1. Epoxy primer 2 thick coats
2. Sanding (leveling) paper P240
3. Spray filler 2 thick coats
4. Sanding (leveling) paper P320
5. Epoxy primer 2 normal coats
6. Sanding (leveling) paper P400
7. 4:1 HS Filling Primer 1 thick coat
8. Sanding (leveling) Paper P500
9. 4:1 HS Filling Primer 1 normal coat
10. Watersanding paper P600
11. Watersanding paper P800
Stule
cron
