cosworth mk2
Re: cosworth mk2
Postby oldskooler » Thu Apr 30, 2009 10:05 am
ya, i plan on going. missed it last year.
oldskooler
Re: cosworth mk2
Postby 24v » Thu Apr 30, 2009 12:31 pm
Are you going to bring your van aswell?
It would be good to see a couple of old transit s at the track...........
Cosworth mk2 crew cab with IFS
24v
Cosworth Powered
Cosworth Powered
Re: cosworth mk2
Postby oldskooler » Thu Apr 30, 2009 6:40 pm
thats the plan lad, will hopefully have the green mk2 in tow.
i posted a couple of pics of mine in members transits.
oldskooler
Re: cosworth mk2
Postby 24v » Fri May 01, 2009 3:22 pm
Nice clean van....
Hope to have mine ready for paint in the next two weeks...........
24v
Cosworth Powered
Cosworth Powered
Re: cosworth mk2
Postby 24v » Mon May 18, 2009 1:18 pm
Hi all
Engine turning over but wont start.I ammusing the auto box so maybe something there is not allowing it start.
We will get there eventually.Alot or head scratching ahead.... :evil:
24v
Cosworth Powered
Cosworth Powered
Re: cosworth mk2
Postby Luke » Mon May 18, 2009 4:42 pm
mine was the relays for the pump and the injectors i had the wires on the wrong way - other than that started up 1st proper try :D
are you getting a spark :?:
Re: cosworth mk2
Postby 24v » Mon May 18, 2009 5:04 pm
No spark.
Put the battery on charge over night to make sure it has proper voltage.....
24v
Cosworth Powered
Cosworth Powered
Re: cosworth mk2
Postby Luke » Mon May 18, 2009 6:11 pm
have you got this drawing :?: i found this the best to follow :D
also check you havent damaged the crank sensor in the swap :idea:
Re: cosworth mk2
Postby 24v » Tue May 19, 2009 10:29 am
Thanks . more head scratching...... :idea:
24v
Cosworth Powered
Cosworth Powered
Re: cosworth mk2
Postby irishtransit » Tue May 19, 2009 7:05 pm
interesting reading.keep us posted.what part of this wonderful land are in?
irishtransit
Re: cosworth mk2
Postby 24v » Wed May 20, 2009 10:25 am
Got it started.... bad earth.
Thanks for all the suggestions. :D :D :D :lol:
24v
Cosworth Powered
Cosworth Powered
Re: cosworth mk2
Postby redeemer » Wed May 20, 2009 8:42 pm
Nice project you ve got there 8)
Are those rims the one used on the mk7 tranny? they are cool 8)
About the power steering , somewhere here there was a conversion to an eletric type pas, and the standard transit box was not modifed. only the shaft column and the pedal box was modded. :idea: I think it was a system off an Opel corsa or similar.
out of interest: how much did you paid for that engine roughly? here that would be in lot of thousands :cry: :cry:
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Re: cosworth mk2
Postby 24v » Thu May 21, 2009 10:27 am
bought a mk3 front end complete to sort steering.Wont be fitted for a while though.
I bought a granada complete with the engine.
24v
Cosworth Powered
Cosworth Powered
Re: cosworth mk2
Postby oldskooler » Tue Aug 04, 2009 6:54 pm
any more progress on this one?
oldskooler
Re: cosworth mk2
Postby 24v » Wed Aug 05, 2009 9:26 am
fitting windows behind driver and passenger doors for rear passengers also made a modern transit bulkhead fit to separate the passengers from the back.
24v
Cosworth Powered
Cosworth Powered
