Hitch wrote:Progress looks realy good,
i have got to do what you have just done on your sills,
i got some primer, then stone chip to go on, then was going to put prmer ontop of stonechip and then diamond white ford paint??
Good idea?? or dont i need the primer ontop of the stonechip??
can i just put the diamond white ontop??
Thanks Hitch
(love the mk7 lights, just ordered mine)
Primer not needed on top on stonechip, it dries off matt and is a good base. Just make sure you give it long enough to through dry and dont use to thick a coat. Its air-drying so will takes ages if you build it up too much.
