1968 LWB Twinwheeler 2,6 V6 project
Re: 1968 LWB Twinwheeler 2,6 V6 project
Postby spitfire » Tue Sep 01, 2009 2:18 pm
The Power steering I have started with fitting does not have long enough travel to let the steering go full lock to lock :roll:
So must figure out something else, found this on Ebay maybe that should be something I could use?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Have also welded in the slots/louvers in the left rear panel, these were removed when the car was converted into a "camper"
FredTransit helped me with measurements were they should be :D
Ketil
Ketil
Norway
ketil.frengen@norgespost.no
2,9 Cosworth V6 1968 mod LWB Twin wheeler
viewtopic.php?f=27&t=49610
spitfire
Postby spitfire » Thu Sep 03, 2009 5:35 pm
Rust is not a crime :D
Left front wheelhousing.
Ketil
Norway
spitfire
Postby Luke » Thu Sep 03, 2009 5:40 pm
coming on 8) 8)
doesnt look too bad once its all cut back like that :D
Postby spitfire » Fri Sep 04, 2009 10:00 pm
Luke wrote:coming on 8) 8)
I agree with you, seen worse :lol:
Ketil
Ketil
Norway
spitfire
Postby redeemer » Sat Sep 05, 2009 6:37 pm
Impresive work there Keitel! 8) 8)
And for 41 years its not that bad at all!
just a question, whee you have striped to bare metal, do you have to use etching primer to have a good bond to the metal? or just apply two pack filler and then paint over it?
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby spitfire » Sat Sep 05, 2009 7:43 pm
redeemer wrote:Impresive work there Keitel! 8) 8)
Two pack epoxy primer first, but I will weld up everything and then sandblast the car and then use epoxy primer.
Ketil
Ketil
Norway
spitfire
Postby spitfire » Wed Sep 09, 2009 4:52 pm
Left upper front wheelwell welded :)
Fred Flintsone edition :roll:
Ketil
Norway
spitfire
Postby spitfire » Wed Sep 09, 2009 4:54 pm
Nearly there
Ketil
Norway
spitfire
Postby spitfire » Thu Sep 10, 2009 7:10 pm
Floor done
Ketil
Norway
spitfire
Postby spitfire » Thu Sep 10, 2009 7:12 pm
Manifolds on :D
Ketil
Norway
spitfire
Postby Luke » Thu Sep 10, 2009 7:41 pm
makes it look so easy :lol: top work 8) 8)
Postby spitfire » Mon Sep 14, 2009 3:29 pm
Getting there :D
Ketil
Norway
spitfire
Postby madmark » Wed Sep 16, 2009 1:23 pm
looking good mate :wink: i would love to weld like that! 8) 8)
Postby spitfire » Wed Sep 16, 2009 3:08 pm
madmark wrote:looking good mate :wink: i would love to weld like that! 8) 8)
Thanks :D
Ketil
Ketil
Norway
spitfire
Postby AlanN » Wed Sep 16, 2009 3:57 pm
Me too.
