The Transit County of Essex!
Re: The Transit County of Essex!
Postby Eugene Speed » Sat Jun 18, 2011 2:22 pm
AlanN wrote:Must be worth a visit to North Weald then :wink:
To be honest Alan I wish I had the time to get to a few meets, work is keeping me very much busy at the moment. I will be aiming to get to the Ace Cafe meet in September purely as it will be the last chance to go before the LEZ comes into force. :(
91 Transit County 4x4
88 Transit 130 armoured van
99 Transit spec lift
90 Fiat Panda 4x4
http://facebook.com/eugene.speed
http://tuffcomputercompany.com
http://transitcounty4x4.co.uk
http://truthsearchersuk.org
Member of the Mk3 Massive! :)
Eugene Speed
Postby AlanN » Sat Jun 18, 2011 10:51 pm
Ill see you there then, or on the streets Southend :D
Postby Eugene Speed » Thu Jun 23, 2011 10:23 pm
A couple more free hours came my way today, so got a couple more jobs done.
Step light salvaged from an old Leyland bus, now grafted into the side loading door step area.
First test fitting of the refurbished dash pod.
Securon four-point harness fitted to the Cobra Monaco bucket seat.
Not much chance of any free time for the next week or two, then hopefully I will have a few days to get some of the bigger jobs done! 8)
90 Fiat Panda 4x4
Eugene Speed
Postby Eugene Speed » Mon Sep 05, 2011 9:32 pm
Finally got round to fitting the CB and PMR radio sets today. Both are on slide mounts so I can take them out of the van when I have to leave it parked.
90 Fiat Panda 4x4
Eugene Speed
Postby Herts » Thu Sep 08, 2011 10:51 am
Hi, what is a PMR radio.
Andy
MK7 - 2.4 RWD/HR/LWB 3.5T 140HP (BIG BOYS TOY!)
Number 1 Emergency Call out Engineer!!!
http://www.hertsplumbinganddrainage.co.uk
Herts
Postby AlanN » Thu Sep 08, 2011 6:13 pm
Herts wrote:Hi, what is a PMR radio.
Andy
Personal or Private Mobile Radio :wink:
Postby transitandy » Thu Sep 08, 2011 10:18 pm
I would not mind getting a cb for my van :wink:
Postby AlanN » Fri Sep 09, 2011 9:04 am
Ive got one and never use it, I could never find anywhere suitable to put it, soo I took it out when Nick painted the van. Will think about putting it back
Postby Vandalism » Fri Sep 09, 2011 1:58 pm
8) county - your number plate bacwards spells HUNI (HUNNY) or HUNI'S (hunny's) :lol:
Postby transitandy » Fri Sep 09, 2011 5:35 pm
AlanN wrote:Ive got one and never use it, I could never find anywhere suitable to put it, soo I took it out when Nick painted the van. Will think about putting it back
im gonna have a look on ebay :wink:
Postby Eugene Speed » Fri Sep 09, 2011 10:24 pm
Andy
The PMR radio is an Icom IC-F410 that covers UHF 410-470Mhz, I have it covering the PMR446 channels, the FRS channels and the local ham repeaters. I also have an Icom IC28-E that covers VHF 136-170Mhz that is going in the van when I can find space to put it!
90 Fiat Panda 4x4
Eugene Speed
Postby Eugene Speed » Fri Sep 09, 2011 10:38 pm
Today I successfully fitted my GPS Tracker unit to the van. Took a bit of fiddling about to get it connecting to the GPRS service, but now it reports the position of the van to my PC, which then plots it in real time onto Google Maps. Also, I can arm/disarm the alarm and disable the engine via SMS. The unit will also text me if the alarm is activated, if the ignition is tampered with, or if the van is moved. Finally, I can dial into the unit and hear what is going on inside the vehicle from my mobile.
Great value unit for £45, but a lot of head scratching to get the realtime GPRS tracking feature working.
90 Fiat Panda 4x4
Eugene Speed
Postby dieselhead123 » Sat Sep 10, 2011 8:41 pm
Hi fella,
where did you get the tracker gadget from? If you don't mind telling
I would like to have a go at fitting one myself, just in case I have to park my van in Essex :lol:
Postby Luke » Sat Sep 10, 2011 8:45 pm
yeah me too :D is there a subscription fee on it :?:
Postby Eugene Speed » Sat Sep 10, 2011 10:55 pm
The tracker is a TK103, loads of them on ebay. No subscription fee as such, just pop in a SIM card and go through the setup sequence. The real-time tracking feature uses GPRS to send information over the internet to your PC, it helps to have a fixed IP address or at least an IP forwarding address from no-ip.com or DynDNS to make the service work.
The control and command of the unit is mainly by SMS, and the unit will communicate back via SMS and/or the GPRS web tracker software. It takes a bit of tinkering to get it all running smoothly, but once it is set up it works great.
I chose to use a PAYG SIM from giffgaff.com, as a £10 topup gives unlimited texts and unlimited internet access.
Wiring the unit is simple enough. There are two antennas, one for GSM and the other for GPS. There is a wiring harness that has all the wires for power, sensors and switching. There is also a microphone for remote monitoring, and also a panic button.
The instructions were not the clearest, although better than some of the 'chinglish' manuals I have had the displeasure of having to use! The unit also comes with GPS Tracker software on CD, again not the best bit of software I have used but works OK.
90 Fiat Panda 4x4
Eugene Speed
