Well today I have started to work on the wiring of my van,
First job was to run a 240volt pick up from under the bonnet to the back of the van; I also ran the split charge wiring through to the back,
Once I had that run through I fixed my inverter to the panel that it would call home and set about connecting everything up,
I joined the 240 input lead to my consumer unit then came out of there with a main earth witch I bolted to the vans body, and another wire to go into the inverter,
Then the wiring would come out of the inverter of to my plug sockets,
The only reason for this is my inverter has a 240 volt pass through as well as a 12 volt input,
The next jobs to do are run the wiring to the very back of the van so I have a plug socket for my fridge, make to front and side panels to hide the wiring, then start running the 12 volt wiring to the different places it needs to be,
I hope that I can work on it tomorrow, just finding the heat is killing me and stopping a lot of play time, just want to kick back and do sod all,
