95 swb custom. BIG very BIG update
Re: 95 swb custom is going to the dark side / day van
Postby snap-on » Fri May 07, 2010 10:42 pm
Yep will do mate. Hope you are going to Transitmania at billing :)
Dave
snap-on
Postby daveyjay-1987 » Fri May 07, 2010 10:44 pm
snap-on wrote:Yep will do mate. Hope you are going to Transitmania at billing :)
kool mate ya we will be there
daveyjay-1987
Postby daveyjay-1987 » Sat May 08, 2010 7:57 pm
Todays update
well there aint one coz of the bloody rain
daveyjay-1987
Postby ozzycustom » Sat May 08, 2010 9:06 pm
we will have to sort a rain cover out tomorrow so we can work in the rain
ozzycustom
Postby daveyjay-1987 » Sun May 09, 2010 10:24 pm
got the afternoon after car boot to do some work on the transit
so todays progress
we almost finished the drivers side step just have one more bit of welding to do on the the step then off to the front inner wheel arch should have all the weldingto done by tomoz evening
a few shots of the new step
i think my welding has improved in the last week
spot the problem but was going to lower the front anyway
slight overkill me thinks but that was all we had to cut the metal
lots more pics tomoz
daveyjay-1987
Postby ozzycustom » Sun May 09, 2010 10:30 pm
the step is startin to look good. its alot better than it was before and it can take my weight when I jump up and down on it and I am big lad
ozzycustom
Postby daveyjay-1987 » Mon May 10, 2010 8:56 pm
todays progres was all under the van today
we have the step totely finished as is the innir wheel arch and the fromt crossmember
all that is to do now welding wise is replace the n/s rear wheel arch
here is a few randi=om pics of the van and me
more updates in a week or so as i have to go into hospital for an opperation
see you all soon
daveyjay-1987
Postby ozzycustom » Wed May 12, 2010 5:07 pm
work on the van has come to a stop. I was going to carry on working on the van as dave has gone in for a hart opp today but 3 days ago I got a bit of metal in my eye. I was wearing goggles when i was working on the van so it must have got in there when dave was grinding and i walked past but I dit not know there was any metal in there till gone midnight. I tryed to wash it out but it was well stuck in there so yesterday I was at A n E were they got some of it out but it has gone in very deep so at 10am today I had a opp on my eye. they used a drill to get 99% of the metal out and now I have a pach over my eye for the next 24 hours and have to go back in a weeks time.
So A message to every one working on there vans always wear goggles even when you are not grinding
also dave if you get online i hope your opp today was ok and i will see you soon ( well I hope to see soon lol )
ozzycustom
Postby daveyjay-1987 » Thu May 13, 2010 9:22 am
hey all the op all went ok and i amback at my mums now just in a bit of pain was given enough drugs to knock an adult out but was wide awake through the whole thing and had to have 4 cups of tea when i got back on the ward
i have been told not to ues my hand so i dont think the van is going to get finished before the 22nd sorry ozzy
catch you all later dudes
daveyjay-1987
Postby MONSTER 0NE » Thu May 13, 2010 7:16 pm
you guys have been busy,
and ozzy sounds like you wher lucky you didnt do any more damage as that sounds painfull, it was bad enough when i had a grinding spark rust on the front of my eye.
Might see you about when you get it on the road.
MONSTER 0NE
Postby ozzycustom » Thu May 13, 2010 8:40 pm
good to know you are ok dave.
well today I took the pach of my eye and I can see so I was back working on the van by 2pm after putting all sorts of drops in my eye. my nieces was there to help me. we got the van all cleaned out and put the ply lining back in the drivers side wall now all the welding is done on that side and started on putting all the camper / day van stuff in there places.
tomorrow if my eye is still ok I am going over to my arnts place to pick up all the wood I have been keeping there and then going over to the van.
I also got A electric sander today so I will try to get all the filler work done.
dave you say you dont think the van will be done by the 22nd. you have little faith mate :wink: I will work day and night if I have to and when you get back you can sit and laugh at me lol :twisted:
ozzycustom
Postby ozzycustom » Sat May 15, 2010 10:43 pm
Hi all
todays update
I started the day by getting all the welding done on the front iner arch and getting it all undersealed. I then took the front drivers side coil spring out and cut the bottom coil out as it had snaped and then did the same to the other side. the van now sits a bit lower but not by much.
I undersealed most of the other side of the van and its looking like new under there now.
then it was onto the bodywork. I got most of the sanding done on the back arch but it still needs some more filler. it will be in paint soon.
I ran out of welding wire again so after going out and getting some more I finished welding the bottom of the outer sill. so thats all done.
tomorrow I will weld the very last bit on the drivers side just under the step and it will all be done on that side and then carry on with the filler and body work.
oh and also I found out why the ABS light is on. the guy I got the van of has put a none ABS hub on the passenger side with a hadit disc. the old parts was in the back of the van and it had a snaped of bolt were the ABS sender bolts on. the worn out brake disc will also explain why the brakes pull more to one side and why the brake pedal has lots of play. my old man has got the snaped bolt out of the hub. so tomorrow I will pick up some new wheel bearings and a new bolt and put all the good parts back on. so it should have good brakes aswell tomorrow :D
jobs left to do for a mot is get new bushes for the back dampers and sort out the front head lights as they have faded. can anyone help with sortin the head lights ?
anyway dave will be back tomorrow so I will ask him to sort some pics out for you all
ozzycustom
Postby Nadjenka » Sun May 16, 2010 7:42 pm
That's some speed :!: :shock: I wish I could do it so fast :( Waiting for the pictures now seems endless....... :lol: :mrgreen:
Nadjenka
Postby ozzycustom » Mon May 17, 2010 10:31 pm
all i will say its now got paint on it and its now a van on the dark side.
oh and the mot is booked for wednesday at 1pm
dave will sort the pics out soon
ozzycustom
Postby daveyjay-1987 » Tue May 18, 2010 12:05 am
here is some pics not in any sort of order but you get the idea
sorry it took so long to put pics on here the computer is playing up
daveyjay-1987
