Thank you BigMonty.
Yesterday I finished the front fog lights.
The first thing was to put the wires on their place behind the front bumper. I wanted to do this quite tight to aboid any loom movements, what might cause unplanned worn-outs:
Next - get with wires into the lamp. Not sure if the rubber o-ring will help in case of salt and water during winter time, but let's hope so
When everything is ok, it time to prepare the wire finishing:
And some extra protection made of thermal shirnk insulation. I know I know - soldering gun shouldn't be used for that, but I'm non-smoker and haven't gas lighter with me
And finally ready to go:
Now it is the time for the switch in the dash. Few days ago I got old Escort fog lights switch with plug, but the Haynes manual is always welcome
Finally it occured, that the old connector has replaced pin 1 and 2 in comparison with what I gound in Haynes for 92-95 Transits. The effect was that the red LED in the Escort switch (91AG15K237AA) was on all the time; I had to flip over wires in the plug (pin 1 with pin 2) and viola
I spent some time on the power for the switch and effectively for the control of the relay. On the beggining I wanted to get it from the Fuse 20, but the access was really poor and, additionaly, there was no good place to connect the ground. I decided to use power from the extra plug I had behind the dash. Not sure what for are the blue and black ones - something like heated rear window and mirrors... or whatever. The good thing is that there was 12V when side lights powered on, so it fulfiled regulations
And this is the time for a dry run
Night view - I had to correct the lights a little bit:
What's next?
First, I have to clean the van inside as the mess is getting terrible and even worse each day
Let's check out the todo list:
- clean the cocpit
- [done] clean and mount doors panels
- [done] mount the roof lining- find suitable rubber and make new rear floor finishing
- find suitable foil/something and renew rear walls panels (I was thinking about some king of glue foil)
- find 3-seat row and mount it
- [done] connect the towing bar electricity
- [done] clean and mount the engine bottom cover (removed when working on the front cross member)
- [done] paint these small plastic wheel caps (these are still in the original silver, wheels are painted a little bit darker)
- [done] replace LED lights in the instrument cluster - they need to be red now
- [done] buy some wires, fuse, relay and mount front fog lightsSo... New floor finishing in the rear of the Van, new side wall ply (I decided to make it finished with gray leatherette / artificial leather), mount seats in the back and clean it inside and outside.
The end is getting closer
What I'm constantly thinking of are swivel fron seats from Euroline. I've found them... 250 EUR per each and they need new cover. Definitely too expensive as for something that needs another 250EUR to replace the material.
