my new mk1 camper
Re: my new mk1 camper
Postby boneheaddread » Thu Jul 14, 2011 6:46 pm
madmark wrote:i spot a problem :shock: :shock: you thermostat hasnt got a hole in ,you will have no end of boiling over and overheating you need to drill a air hole :wink: :wink:
as in the photo drill a air hole :wink: :wink:
Hi , oops just read this post and already fitted it , I will do it tomorrow , what size hole ???? why do you do this??? is it to let some pressure through??? why is it not done when the thermostate is made as the one I have is the right one for the van???
boneheaddread
Postby boneheaddread » Thu Jul 14, 2011 6:54 pm
Hi ,ok had enough now , I will finish of tomorrow , just got to fit the alternater and bracket , oil filter do the tappets rocker covers and air filter , then turn the key , it was a non runner when I bought it so I have never heard it ( or any v4 ) run yet so fingers cross
john
boneheaddread
Postby madmark » Thu Jul 14, 2011 6:56 pm
mate its a cock up with the new stats :roll: it stops the airlocks :wink: it doesnt have to be a big hole,did the old stat have a hole in it????
Postby boneheaddread » Thu Jul 14, 2011 7:45 pm
Hi , it never had one in it???
boneheaddread
Postby malta transit » Thu Jul 14, 2011 10:05 pm
Image[/quote]
Can't wait to see my engine ( V4 ) in this state. Nice work 8)
malta transit
Our man in Malta!
Postby madmark » Fri Jul 15, 2011 12:44 pm
:roll: well maybe it was the same with no hole and they removed it :lol: :lol:
is it running yet??????
Postby rogerw » Fri Jul 15, 2011 4:49 pm
I put a new thermostat in my motorbike and it had a small hole in it - just lets the water flow round so thermo can heat up I suppose.
Camper looks good a 70s!
2003, petrol
rogerw
Postby boneheaddread » Fri Jul 15, 2011 8:11 pm
Hi again , well it started first time , its running a little to fast for my liking , there is a thick brown wire with a spade end , that I have no idea where I took it off from , and now there is a load of bodywork to do ( not my best skill) but its a runner ,thanks to all the people that helped and gave advice , I am going to sit in my van now
john
boneheaddread
Postby madmark » Sat Jul 16, 2011 1:07 pm
when you say running fast cant you turn it down? looks good :wink:
Postby transitandy » Sat Jul 16, 2011 2:14 pm
very nice work m8y :)
Postby boneheaddread » Sat Jul 16, 2011 3:34 pm
madmark wrote:when you say running fast cant you turn it down? looks good :wink:
Hi , yeh, I just had enough last night spent 8 hours on yesterday just wanted to hear it run before I come in ,
just been out and slowed the tickover down , sounds sweet now, I was well lucky not to have had any bent valves but all seems ok , just the 1 bent inlet pushrod ( no 7) and the fibre cam wheel , everthing else was fine ,
just in case anyone has any camper info mine has a sheldon hightop on it with a formica inside , but there are traces of oak faced wood here and there , so I was wondering if it started life as a pop top with the old skool fittings and at a later date had the high top fitted and the new inside ??????
has anybody got any inside photos of mk1 campers or sheldon conversions ???
and thanks for all the comments on the clean engine , just got to try and clean myself now
John
boneheaddread
Postby Vandalism » Sat Jul 16, 2011 3:42 pm
my dads old camper was a high top sheldon i think - ill dig out some photos and up load them soon
Postby Vandalism » Sat Jul 16, 2011 8:05 pm
this is the only inside pic of my dads sheldon hightop camper - if i remember rightly the wood was just a chipboard type with a very thin formica/paper wood efect over the top - altho someone may have added the oak into your camper or it was used to build the main frame of the cupboards...hope this pic helps
Postby boneheaddread » Sun Jul 17, 2011 1:07 pm
Hi , snap its the wood electric panel that looks out of place , and there is matching wood that runs around the top , it just looks like it was upgraded at some time ,
john
boneheaddread
Postby Vandalism » Sun Jul 17, 2011 1:15 pm
yes somones definatly upgraded ur camper inteior to a more modern one as that carpeted cupboards and the door fronts are definatly not original
