ITS GREEEEEN
Postby pete_the_4x4 » Fri Jan 19, 2007 8:04 am
yes thats why i have a 460 sitting about
if you think my van is dirty you should see my pants
pete_the_4x4
Postby stevew » Fri Jan 19, 2007 3:22 pm
Compare that with prices in the US.
Cheapest regular "gas" is $1.82 per US gallon (source: gasbuddy.com)
Thats equivalent to 25p per litre! :shock: :evil: (or 0.63 Aussie Dollars)
Bah! No wonder SUVs are so popular!
Steve
Van Cam, service suspended (no van!) (no cam either!)
stevew
Postby Sundowner » Fri Jan 19, 2007 9:39 pm
im only going to be running petrol for a little while then it will be on lpg
i thought i was restricted to a max capacity of 466ci but the van is listed as a commercial vehical so i have alot more freedom with engine size so the twin turbo LPG setup is looking very tempting so duz the 557ci stroker for $2600
Sundowner
Postby zoz from oz » Sat Jan 20, 2007 12:46 am
Hi sundowner..that's one helluva donk that you're fitting to your tranny..Gonna be very satisfying cruising the Highway..How's it comong along?
Whats this wire do?
zoz from oz
Postby Sundowner » Sat Jan 20, 2007 2:45 am
zoz from oz wrote:Hi sundowner..that's one helluva donk that you're fitting to your tranny..Gonna be very satisfying cruising the Highway..How's it comong along?
well i havnt done anything for a week so im going to make a tail shaft tomorrow and mount the steering box
Tracked down a sump that will clear the x member and i still need to space the gearbox x member 6mm of the body to get correct gearbox > pinion angle then the engine box will be made
i need to get it done by Aug as im putting it in a burnout comp @ the southcoast nats
Sundowner
Postby Sundowner » Fri Jan 26, 2007 12:41 pm
OK finally got to do some work on the van
Today i decided to mount the steering column its from a 95 ford falcon
I chose this column because it was adjustable in hight and length but not so i can have this feature in my van but more for the reason that it gives me some flexability with the mounts and length of the column for doing this kind of conversion i can simply adjust it to suit the van
Sundowner
Postby Sundowner » Fri Jan 26, 2007 11:46 pm
pics added
Will look better once its painted to match the rest
Had to make a bottom mount good thing is it already had holes in the pedal box for one
its even got an airbag, but it wont be staying
a keen eye will reconise this bit as being the top section of the factory transit steering tube that has been welded to the falcon column i used it because i needed to support the lower section of the column and it was a perfect fit even the bearing is the right size and i can also use the factory tranit rubber boot to seal it off
Sundowner
Postby Luke » Fri Jan 26, 2007 11:59 pm
nice work mate - your half way to the ifs :wink:
what wheel are you gonna fit :?: - ive just been doing mine (mk4 column) and when i fit my wheel (deep dish springalex) its close to the driver!
Postby Sundowner » Sat Jan 27, 2007 12:38 am
Luke wrote:what wheel are you gonna fit :?:
Ill tell you in a few hours
Sundowner
Postby Sundowner » Sat Jan 27, 2007 1:57 am
Ok new wheel is on
I had to modifiy the boss kit as they dont make sports wheels for this column due to it being fitted with an airbag
Sundowner
Postby zoz from oz » Sat Jan 27, 2007 12:39 pm
Good looking fit and there's nothing like having the blinker and wiper controls on the correct side of the column...Looks like that engine took up a chunk of your left leg room..
Whats this wire do?
zoz from oz
Postby Sundowner » Sat Jan 27, 2007 10:16 pm
zoz from oz wrote:Looks like that engine took up a chunk of your left leg room..
Yeah it took up some realestate but i will be building a foot rest into the new engine box
Sundowner
Postby Sundowner » Thu Feb 01, 2007 9:31 am
The power steering it getting closer to completion :D just need to do the final on the box mounting bracket and get the steering box to column joint resplined
Sundowner
Postby Sundowner » Sun Feb 04, 2007 11:20 am
Steering box is in YAY
Sundowner
Postby Sundowner » Wed Feb 07, 2007 8:37 am
Got my pitman arm back today
It from a HQ Holden i had to use it as the transit item set the drag link out to far and it fouled the tyre on full lock
Was not a bolt on jod though, i had to modify the 4 wide locating splines so the pitman could be rotated and i also had to get the tapered hole that the drag link bolts to changed to the inside and enlarged to suit the transit rod end
But as you can see its all bolted up and turning, I now have 3 turns lock to lock :D
all i need to do now is connect the column to the box
Sundowner
