i cant see exactly what problems you are having with the mountsdipstick wrote:Guy, i haven't seen a Pinto mount.... but i was thinking if 'could' use the ally Granada/Scorp mounts instead of the massive steel Ford Amby ones, then half the problems would go away ... i could connect up the oil return to the sump, and use the remote oil filter and cooler, no problem!
... cheers
yeah thats what oxtony didGuy88 wrote:cutting them bending them vertical and using the ally mounts. apparently they are all in the right place.
i wondered if they were the same as the Di onesdipstick wrote:As an aside, does anyone know where i can find Transit engine mount rubbers, the rubber things with the two 10mm studs top and bottom
