no problem gurj so long as it comes back with a half decent sterio fitted something similar to yours
spent a bit of time on this today, fitted the new (ebay 2nd hand) amil vakve on and it didnt work - put a voltage to it and it's u/s
a bit annoying as it was supplied as tested working ok
we really wanted that working fine before we start messing with the ecu but we couldnt resist
tried the chipped ecu - didnt work
stu then remembered the chip wasnt actually fitted
it was about 3 years ago we bought it
fitted the chip and took it for a blast 25psi boost straight away
as the rest of it isnt ready i put the standard one back on for now
unfortunatly we still couldnt get the MAP senser to work - i even swapped the wiring over and still no good
the ecu (chipped one) is a 2wd but the rest is 4x4 - is that a problem
anyone
the injectors have been sent off we're waiting for them to come back, and now we need another amil valve, but it's still worth taking to north weald as it is so it'll be there definatly now
