Puk, a troublesome fairy!
Re: Puk, a troublesome fairy!
Postby jonochap » Sun Feb 17, 2013 10:30 am
Thanks chaps :) food for thought...
Owner of not so troubled puk :)
jonochap
Postby johnsvan » Sun Feb 17, 2013 11:15 am
Hi Jono,
I'm not familiar with your engine but some petrol engines have a water cooled inlet manifold to help with the fuel vaporization issue (also may have a heat shield under the carb). If your inlet manifold is plumbed in you should check for air locks in the manifold/manifold pipes. There could be a bleed point to let the air out. If you have a service manual, look at the section on refilling with coolant, it should give the bleeding procedure, if there is one.
Mk5 1999 2.5D 100L high roof
johnsvan
Location: Ware, Herts. (10 Miles north of the M25 on the A10)
Postby jonochap » Sun Feb 17, 2013 12:52 pm
Aw thanks you all. Having heeded advice i had a look when i was at wickes just now buying some timber to repair the front underside of the camper bit.
Something smelt really awful which i reckon might be the clutch burning out, but while moving all the leads away from manifolds etc i found that the main ht lead to the dizzy was loose so pushed that back in and she seems to be running better now (and with no smell but i think that might just be wishful thinking)
I am still learning!!! :)
jonochap
Postby jonochap » Sun Feb 17, 2013 12:53 pm
And thanks JV, puk has an old 2.0 pinto, very basic block with very few whistles and bells, just an inept owner :)
jonochap
Postby mobilevanman » Sun Feb 17, 2013 12:55 pm
but learning with each new occurence lol
why not if u dont someone will
mobilevanman
Postby jonochap » Sun Feb 17, 2013 3:39 pm
Yip, it would be great to have the same problem twice!
jonochap
Postby robbie.cee » Sun Feb 17, 2013 5:05 pm
ha ha so im ok there then had my dizzy jump out twice lol actually properly tightened down now :lol:
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby jonochap » Sun Feb 17, 2013 8:36 pm
Yip, at least you could spot the popped dizzy the second time! Note to self, must make a point and check picture for the engine bay!
jonochap
Postby jonochap » Sat Feb 23, 2013 11:46 am
Still running a bit lumpy when idling...bit strange
jonochap
Postby camper extraudinair » Sun Feb 24, 2013 12:35 pm
Hi J.C.
I have just finished working on a mk2 transit with a pinto 2lt petrol
engine with the same problem which turned out to be a leaking
inlet manifold gaskett.
a very straight forward job to do.
Hope you get it sorted soon.
best wishes C.E.
camper extraudinair
Postby jonochap » Sun Feb 24, 2013 4:42 pm
Aw thanks CE, will have a read up on that. Been told the exhaust manifold is loose too...slowly but surely.
Have a really nice type 9 box to fit though courtesy of transit dave of the bentley bros. never seen so many transits in one place, all in different states of need. Really really nice guys to deal with and used to be on the forum some years back. He said i could only have a 9 as i had a petrol and wouldnt let me have one if i had a derv...
Also have bushes now to fit the fated new rear springs that dave found me too...
Awaiting mobilevanman eagerly on saturday to watch him work his butt off while i make coffee and chuckle so all good! Very excited about the next week or so... :) :)
jonochap
Postby jonochap » Sun Feb 24, 2013 4:43 pm
I think we did the inlet manifold gasket when we changed the carb over last year though...
jonochap
Postby robbie.cee » Sun Feb 24, 2013 6:40 pm
bushes fitted dude? :D
Had
MAKE IT FIT
robbie.cee
Postby jonochap » Sun Feb 24, 2013 6:59 pm
Naw, not yet, just waiting for the mvm to bring the technical know how, the equipment, the knowledge, the bits i forgot to buy and the time, but apart from that im ready to go... :)
jonochap
Postby mobilevanman » Mon Feb 25, 2013 12:05 am
im ready to the weekend is going to be eventfull then lol
mobilevanman
