mk4 LWB Project! UP DATE! one side nerly done in blue !!!
Re: !LWB MK4 Project!!sorted my mig clamp and got some more stuf
Postby intransit89 » Thu Jul 03, 2008 10:58 pm
Guy88 wrote:
MrMPuk wrote:Where are you getting your metal from? Looks like you are putting rust back in!
:lol: :lol:
Make sure the metal is completly clean rob
Also the welds look too good for yours mate :lol: :lol: :lol:
well it is mine lol
dave was busy trying to see how his gear box comes of :( :x
intransit89
Re: !LWB MK4 Project!!welding chassis bits and some good news
Postby MrMPuk » Thu Jul 03, 2008 10:59 pm
off off off off off off off off!!!
Postby intransit89 » Thu Jul 03, 2008 10:59 pm
MrMPuk wrote:off off off off off off off off!!!
ok ok ok ok
intransit89
Postby intransit89 » Thu Jul 03, 2008 11:03 pm
dave look at this
viewtopic.php?f=18&t=18935
should be fun tomorow :lol: :shock: still dont matter what happens when you cant go out anyway
intransit89
Postby intransit89 » Sat Jul 05, 2008 1:53 am
mig this up to day and then looks at how it should go together
just need to cut that bit of next to the inner quotor :wink:
:D
intransit89
Postby jamface » Sat Jul 05, 2008 1:08 pm
WHY are you in bed with that piece? :wink:
'95 SWB semi-high top transit camper to be, dark blue petrol :)
jamface
Postby transit killer » Sat Jul 05, 2008 2:08 pm
I think that might be oncles quilt ?
2004 Transit 350 LWB Recovery
transit killer
Postby intransit89 » Sat Jul 05, 2008 2:21 pm
you know what thay say look after your transit and your transit looks after you :lol:
ok i only brought it in last night to take pics as it was dark again to get a better pic so you can see how the rebuild chassis will go together :wink:
intransit89
Postby madmark » Sat Jul 05, 2008 2:23 pm
:shock: :shock: :shock: :shock:
Postby Jezclayton » Sat Jul 05, 2008 3:16 pm
Rob
Wow, your welding really is looking alot better. Bet you wish you had bought the new earth clamps earlier. A lesson for us all there.
I don't think I would be too impressed if you started using my bed as a workbench. :x
Transit Connect 2019 1.5 Tdci EcoBlue
Jezclayton
GLX Posse
Postby intransit89 » Sat Jul 05, 2008 3:29 pm
Jezclayton wrote:Rob
lol thanks for the comment :D
yes i did wish i know it was the earth clamp all a long i throught its the welder fooked or its me :lol:
but any thing i weld now from car body metal to 2mm it just welds nice :wink:
intransit89
Postby intransit89 » Sat Jul 05, 2008 4:02 pm
some more good news i tock my gear box plastic cover of and tock the rubber plug out on the left side and put a torch in and its a silver new clutch it looks like :D
i was trying to see if my clutch had same number on as daves but couldnt see a code
daves is mf 265 as we phoned ford transit parts and the bloke said the hicube had the bigger clutch in then the normal transits :wink:
heavy duty ones about 1 inch bigger and = bigger price :shock: 160.00 odd as in mine is 45.00 lol
intransit89
Postby transit killer » Sat Jul 05, 2008 7:40 pm
Thats news to me, they must have a bigger flywheel fitted on highcubes then :?:
I have done clutches on them and cant remember any differences
transit killer
Postby intransit89 » Sat Jul 05, 2008 9:54 pm
note gear box dont come of :( :evil: tock proshaft of etc and starter motor and exhurst
and all bolts to gear box and losen the gear box cross member you can push the gear box left to right but wont go up or down just moved all the engine
:roll: :roll: :roll: daves thinking of going some where else like fiat garage :lol: :lol:
been doing it since 4 and still going now :roll: starting with head ake to :x
oh and dont know if there diffent or not no the other transits but the proshaft bolts are t55 trox x4 of them :wink:
intransit89
Re: !LWB MK4 Project!!pissing gear box :(
Postby transit killer » Sat Jul 05, 2008 10:17 pm
sounds like either the engine to bell-housing locating lugs are seized in solid or the gearbox input shaft is seized in the spigot bearing on the end of the crank :wink:
Theres not much else it can be in my experience.
How much gap have you managed to get between the engine block and bell housing?
transit killer
